i am making an instrument, and all i need is simple sound output that sounds solid and clean. the way this sample is intended to work, is that you have three buttons a speaker and a potentiometer. the potentiometer range is split into thirds. when a button is pressed it emits a tone form the speaker. depending on which position the potentiometer is in, it should play different notes. so effectively you can play 9 different notes with 3 buttons.
my problem comes with my process. the problem is that each time the code loops, it plays the tone, therefore the tones played upon a button press go on and off at a insanely high rate, distorting the notes and forcing me to add a delay to recognize notes audibly. my question is how can i change my code so that when a button is pressed, the entire code does not loop. keep in mind that i need to be able to play multiple notes at once if possible, or at least be able to play a note then another note say with a 10 millisecond gap. the last requirement is that if i am holding a button, and i turn the potentiometer, the tone with change according to the zone i am in without removing my finger from the button.
i know this sounds complicated, especially for a first post, but if i can get this to work, it will really go somewhere.
thanks for the help in advance and hello to the community!
with out further adieu, the code, well commented too.
RANGED INSTRUMENT SAMPLE
this is is a test for the changing of notes an instrument plays with a potentiometer, so with three
buttons and a potentiometer, nine notes can be played. this will be part of a larger project in
the near future.
PINS:
digital:
0 = button 1 to ground
1 = button 2 to ground
2 = button 3 to ground
8 = speaker output to ground
analog:
0 = potentiometer from 5v+ to pin 0 and lastly ground
#include "notes.h" //full scale of notes to read from
boolean button[] = {0, 1, 2}; //create array for button pins
boolean speaker = 8; //sets speaker pin
boolean buttonset = 0; //variable for reading button push
int notes[] = { NOTE_FS3, NOTE_AS3, NOTE_CS4, NOTE_DS3, NOTE_FS3, NOTE_AS4, NOTE_CS3, NOTE_FS3, NOTE_GS4 };
// notes used in this practice sketch above ^
int potpin = 0; // potontiometer set to analog pin 0
int potMin = 0; // minimum value for potontiometer range
int potMax = 1023; // maximum value for potentiometer range
for(int x=0; x<3; x++) {
pinMode(button[x], OUTPUT); // sets buttons to outputs
digitalWrite(button[x], HIGH); // recognizes buttons as HIGH
int potval = analogRead(potpin); // realtime value of the potentiometer
int range = map(potval, potMin, potMax, 0, 2); // splits the potentiometer into thirds and
//sets the thirds to a number: 0, 1 or 2
buttonset = digitalRead(button[x]);
switch(range) { // switch cases are the three positions of the potentiometer, so each third is a case
case 0 : // first third of the potentiometers range
if(buttonset == LOW && button[x] == 0) { // if the button is pressed, and it is the first button,
tone(speaker, NOTE_FS3, 25); // then play note F sharp
delay(20);
if(buttonset == LOW && button[x] == 1) { // if the button is pressed, and it is the second button,
tone(speaker, NOTE_AS3, 25); // then play note A sharp
delay(20);
if(buttonset == LOW && button[x] == 2) { // if the button is pressed, and it is the third button,
tone(speaker, NOTE_CS4, 25); // then play note C sharp
delay(20);
else { // if no button is pressed, dont make sound
noTone(speaker);
case 1 : // second third of potentiometer range
tone(speaker, NOTE_DS3, 25); // then play note D sharp
delay(20);
delay(20);
delay(20);
noTone(speaker);
case 2 : // last third of potentiometer range
tone(speaker, NOTE_CS3, 25); // then play note C sharp
delay(20);
delay(20);
tone(speaker, NOTE_GS4, 25); // then play note G sharp
delay(20);
noTone(speaker);
