Tone library + accel hang
Guys,
I have a lilypad with the standard accelerometer and a buzzer. I can read the accel just fine but if I use the tone library as well I can read the accel three times, make three tones, and then it all just hangs. Is this some wierd interrupt thing?
Code follows … thx in advance.
#include <Tone.h>
#include <bassdll.h>
#include <debug.h>
#include <stdlib.h> // for malloc and free
void* operator new(size_t size) { return malloc(size); }
void operator delete(void* ptr) { free(ptr); }
// Ardy Jacket
// leds, buzzers (left/right), vibrator, acelerometer
const int groundPin = 18; // analog input pin 4 – ground
const int powerPin = 19; // analog input pin 5 – voltage
const int xPin = 16; // x-axis of the accelerometer ANALOG
const int yPin = 17; // y-axis ANALOG
const int zPin = 18; // z-axis (only on 3-axis models) ANALOG
int ledPins[4];
int rightBuzzerPin = 6;
int leftBuzzerPin = 7;
int vibratorPin = 8;
//int x,y,z;
// Setup led pins
for (int count = 0; count < 4; count++) {
ledPins[count] = 2 + count;
pinMode(ledPins[count], OUTPUT);
pinMode(leftBuzzerPin, OUTPUT);
pinMode(rightBuzzerPin, OUTPUT);
pinMode(vibratorPin, OUTPUT);
pinMode(xPin, INPUT);
pinMode(yPin, INPUT);
pinMode(zPin, INPUT);
// Read the accelerometer.
void readAccel(int &x, int &y, int &z) {
x = analogRead(xPin);
y = analogRead(yPin);
z = analogRead(zPin);
Tone tone1;
Tone tone2;
int x = 0, y = 0, z = 0;
readAccel(x,y,z);
char buffer[56];
sprintf(buffer, “(x,y,z) = (%d,%d,%d)”, x, y, z);
Serial.println(buffer);
sprintf(buffer, “(x,y,z) = (%d)”, NOTE_A4 + x / 100);
tone1.begin(rightBuzzerPin);
tone1.play(NOTE_A4,100 );
// tone2.begin(leftBuzzerPin);
// tone2.play(NOTE_A4);
delay(800);
Not necessary - they're analogue pins, best change the numbering to match.
I'd probably dump the "sprintf"s too.
Please use the # key when posting code.
Ok - will do.
The sprintf’s are a good buffer over-run candidate but would they affect timing here or something?
How are you powering the setup ?
It sounds like maybee your powersupply can not deliver enough current ??
sprintf looks OK for buffer size, but I just don't like them! (Well, not on an Arduino, anyway) [edit]Just a moment - in the sketch above, the declarations of x,y and z are commented out - how does that work? Are you sure you've posted your latest code?[/edit]
The x,y,z reappear in the loop.
I tried powering off an external battery. Very good idea that - you never really know if you're sending enough current. However, vene then we get three beeps and it stops. Same as before.
This makes no real sense to me.
Ok - I simplified this and the issue is the tone library
I still get three beeps for the following
//  readAccel();
  Tone tone1;
  tone1.play(NOTE_A4,550);
  delay(600);
Oh, and I did think that the Tone object was getting destroyed so I put it as a global and it made no difference.
Got it. People who call Tone::begin repeatedly in the loop need their head examined.
