Hi and thank you for reading. I modified the "tonePitchFollower" project (in the IDE examples under "digital" tab) to use a softpot as a ribbon controller to play melodies. Its working great but I'm wondering if there's a way to get no tone until the softpot is pressed. In other words, I am playing in one octave, 440-880Hz, so I could make the range that plays those pitches 10-1023 and make 0-9 silent somehow but how? I've tried a few ways to do it but no success. I'd appreciate any help!
This sketch is what I'm using so far (on an Uno):
Pitch follower
Plays a pitch that changes based on a changing analog input
circuit:
- 8 ohm speaker on digital pin 9
- photoresistor on analog 0 to 5V
- 4.7 kilohm resistor on analog 0 to ground
created 21 Jan 2010
modified 31 May 2012
by Tom Igoe, with suggestion from Michael Flynn
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Tone2
// initialize serial communications (for debugging only):
// read the sensor:
int sensorReading = analogRead(A0);
// print the sensor reading so you know its range
Serial.println(sensorReading);
// map the analog input range (in this case, 400 - 1000 from the photoresistor)
// to the output pitch range (120 - 1500Hz)
// change the minimum and maximum input numbers below depending on the range
// your sensor's giving:
int thisPitch = map(sensorReading, 0, 1023, 440, 880);
// play the pitch:
tone(9, thisPitch, 10);
delay(1); // delay in between reads for stability
Thanks so much for the reply! noTone() sounds promising! I tried a few ways of implementing it but im a beginner with syntax. The code below didnt work but am I on the right track?
Pitch follower
circuit:
created 21 Jan 2010
// read the sensor:
int thisPitch = map(sensorReading, 10, 1023, 440, 880);
// play the pitch:
noTone(sensorReading, 0-9);
Thank you for the links, I read them and I'm getting closer (I think). This code returned error:
/var/folders/xg/kmsx7p8j0j1gl5wl80sgt86w0000gn/T/arduino_modified_sketch_993701/tonePitchFollower.ino: In function 'void loop()':
tonePitchFollower:39:21: error: expected ')' before numeric constant
if (sensorReading 0-9)
exit status 1
Pitch follower
circuit:
created 21 Jan 2010
// read the sensor:
// play the pitch:
{noTone(9);}
This time I didn't get an error! But I also didnt get "no tone". The serial monitor is reading 0 but there is a tone. Would any of you be able to explain how to fix that? Thanks so much!
Pitch follower
circuit:
created 21 Jan 2010
// read the sensor:
// play the pitch:
if (sensorReading <10)
noTone(9);
I got it working! There is no tone until the pot is touched. Thank you so much for pointing me in the right direction, guys! The working code is below. Does it look right to you all?
Pitch follower
circuit:
created 21 Jan 2010
// read the sensor:
// play the pitch:
if (sensorReading >9){
delay(1); }
if (sensorReading <10){
noTone(9);}
