Tones Q with Due
I'm tring to use the the MIDIUSB_buzzer example, but I get the errors regarding the 'tone and noTone'.
I then found this sketch to implement tones on the Due, and have added it to the MIDIUSB_buzzer sketch, but I still get the same error?;
http://forum.arduino.cc/index.php?topic=363557.0
Hears my current example sketch;
 * MIDIUSB_buzzer.ino
 * Author: Paulo Costa
#include <MIDIUSB.h>
#include "pitchToFrequency.h"
#include <stdint.h>
#include <Arduino.h>
//#define BUZZ_PIN 9
#define TONE_PIN      2 // TIOA0
static Tc *chTC = TC0;
static uint32_t chNo = 0;
const char* pitch_name(byte pitch) {
  static const char* names[] = {"C", "C#", "D", "D#", "E", "F", "F#", "G", "G#", "A", "A#", "B"};
  return names[pitch % 12];
int pitch_octave(byte pitch) {
  return (pitch / 12) - 1;
void noteOn(byte channel, byte pitch, byte velocity) {
  tone(BUZZ_PIN, pitchFrequency[pitch]);
  Serial.print("Note On: ");
  Serial.print(pitch_name(pitch));
  Serial.print(pitch_octave(pitch));
  Serial.print(", channel=");
  Serial.print(channel);
  Serial.print(", velocity=");
  Serial.println(velocity);
void noteOff(byte channel, byte pitch, byte velocity) {
  noTone(BUZZ_PIN);
  Serial.print("Note Off: ");
void controlChange(byte channel, byte control, byte value) {
  Serial.print("Control change: control=");
  Serial.print(control);
  Serial.print(", value=");
  Serial.print(value);
  Serial.println(channel);
   configureToneTimer();
  midiEventPacket_t rx = MidiUSB.read();
  switch (rx.header) {
    case 0:
      break; //No pending events
    case 0x9:
      noteOn(
        rx.byte1 & 0xF,  //channel
        rx.byte2,        //pitch
        rx.byte3         //velocity
    case 0x8:
      noteOff(
        rx.byte2,        //pitch
        rx.byte3         //velocity
    case 0xB:
      controlChange(
        rx.byte2,        //control
        rx.byte3         //value
    default:
      Serial.print("Unhandled MIDI message: ");
      Serial.print(rx.header, HEX);
      Serial.print("-");
      Serial.print(rx.byte1, HEX);
      Serial.print("-");
      Serial.print(rx.byte2, HEX);
      Serial.print("-");
      Serial.println(rx.byte3, HEX);
void configureToneTimer() {
  // Configure TONE_PIN pin as timer output
  pmc_enable_periph_clk( ID_PIOB ) ;
  int result = PIO_Configure( PIOB,
           PIO_PERIPH_B,
           PIO_PB25B_TIOA0,
           PIO_DEFAULT);
  Serial.println(result);
  pmc_set_writeprotect(false);
  pmc_enable_periph_clk(ID_TC0);
  TC_Configure(chTC, chNo,
        TC_CMR_TCCLKS_TIMER_CLOCK4 |
        TC_CMR_WAVE |         // Waveform mode
        TC_CMR_WAVSEL_UP_RC | // Counter running up and reset when equals to RC
        TC_CMR_ACPA_SET |     // RA compare sets TIOA
        TC_CMR_ACPC_CLEAR );  // RC compare clears TIOA
  chTC->TC_CHANNEL[chNo].TC_IER=TC_IER_CPCS;  // RC compare interrupt
  chTC->TC_CHANNEL[chNo].TC_IDR=~TC_IER_CPCS;
void setFrequencytone(uint32_t frequency)
  if(frequency < 0 || frequency > 100001) {
    TC_Stop(chTC, chNo);
    return;
  const uint32_t rc = VARIANT_MCK / 128 / frequency;
  const uint32_t ra = rc >> 1; // 50% duty cycle
  //const uint32_t ra = rc >> 2; // 20% duty cycle
  TC_SetRA(chTC, chNo, ra);
  TC_SetRC(chTC, chNo, rc);
  TC_Start(chTC, chNo);
Does anyone know what wourds I should use instead of 'tone and noTone', to get this working?
Dizzwold.
Can you show me where, in that post, tone() was called?
Hi PaulS,
It's not in that post, It's in the MIDIUSB_buzzer example sketch;
#define BUZZ_PIN 9
  noTone(BUZZ_PIN);
    case 0:
    case 0x9:
      noteOn(
        rx.byte2,        //pitch
        rx.byte3         //velocity
    case 0x8:
      noteOff(
        rx.byte2,        //pitch
        rx.byte3         //velocity
    case 0xB:
      controlChange(
        rx.byte2,        //control
        rx.byte3         //value
    default:
      Serial.print("-");
      Serial.print("-");
      Serial.print("-");
Dizzwold.
Hi PaulS,
OK, got it. Remove tone and noTone from the sketch.
Cheers PaulS.
Regards.
Dizzwold.
