Hi everybody
I have a Problem with my actual Project.
I use a 4D system display and have implemented the user interface in Visi- genie.
Now I would like to evaluate the buttons from the keyboard and display on the display (LED digits) . I receive the error message " too few arguments to function" unfortunately I dont understand this message and dont know what to do . I hope you can help me with my problem . Many thanks in advance
//////////////////////////////LIBRARIES EINLESEN//////////////////////////////
#include <genieArduino.h>
#include <stdio.h>
#include <stdint.h>
#include <ctype.h>
#ifndef TRUE
#define TRUE (1==1)
#define FALSE (!TRUE)
#endif
Genie genie;
#define RESETLINE 13 // Der Touch-Display besitzt den Resetpin mit der Nummer 13
void myGenieEventHandler (void)
genie.DoEvents();
genieFrame Event;
genie.DequeueEvent(&Event); // Remove this event from the queue
int KeyboardValue;
if (Event.reportObject.object == GENIE_OBJ_KEYBOARD) // If this event is from a Keyboard
if (Event.reportObject.index == 0) // If from Keyboard0
KeyboardValue = genie.GetEventData(&Event); // Get data from Keyboard0
KeyBoard(KeyboardValue); // pass data to the calculatorKey function for processing
void KeyBoard(int key)
switch (key)
case '1':
genie.WriteObject(15, 0, 1);
case '2':
genie.WriteObject(15, 0, 2);
case '3':
genie.WriteObject(15, 0, 3);
case '4':
genie.WriteObject(15, 0, 4);
case '5':
genie.WriteObject(15, 0, 5);
case '6':
genie.WriteObject(15, 0, 6);
case '7':
genie.WriteObject(15, 0, 7);
case '8':
genie.WriteObject(15, 0, 8);
case '9':
genie.WriteObject(15, 0, 9);
case 'd':
genie.WriteObject(15, 0, 0);
case 'o':
genie.WriteObject(15, 0, 12345);
//////////////////////////////VOID SETUP//////////////////////////////
// Touch-Display initialisieren (UART ==> TX und RX)
genie.Begin(Serial);
genie.AttachEventHandler(myGenieEventHandler);
pinMode(RESETLINE, OUTPUT); // Resetpin als Output deklarieren
digitalWrite(RESETLINE, 0); // Touch-Display reseten
delay(100);
digitalWrite(RESETLINE, 1); // Touch-Display initialisieren
delay (3500); // 3,5 Sekunden Wartezeit nach dem Resetvorgang; es ist wichtig das diese Wartezeit eingehalten wird
genie.WriteContrast(10); // 1 = Display ON, 0 = Display OFF // Für die Bildschirmmodule uLCD43, uLCD-70DT und uLCD-35DT kann 0-15 für die Bildschirmhelligkeit eingesetz werden ==> 0 = Display OFF bis 15 = Max Brightness ON.
//////////////////////////////VOID LOOP//////////////////////////////
void loop(void)
KeyBoard();
