Too Few Arguments
I am getting the following error when compiling a sketch.
Arduino: 1.5.7 (Mac OS X), Board: "Arduino Yún"
Build options changed, rebuilding all
Temboo_Email_Test.ino: In function 'void loop()':
Temboo_Email_Test.ino:71:13: error: too few arguments to function 'void logData(String)'
Temboo_Email_Test.ino:15:6: note: declared here
  enabled in File > Preferences.
What is strange is that the function and the call to the function work just fine in another sketch.
This is the code I am using:
/* Yun specific */
#include <Bridge.h>
#include <Process.h>
/* Temboo Specifc */
#include <Temboo.h>
#include "TembooAccount.h" // Contains Temboo account information
int maxCalls = 10;
int calls = 0;
const short broadcastInterval = 10; // Interval between broadcasts in seconds
/* SD Card on Yun */
#include <FileIO.h>
/* Hall Effect Sensor */
const int hall_output = 12;    // output of the hall effect sensor
int peaks = 0;                // peaks since last transmission
/* Time Stamp */
unsigned long epoch;          // UNIX timestamp when Arduino starts
unsigned long millisAtEpoch;  // millis at the time of timestamp
unsigned long lastBroadcast;     // timestamp at last broadcast
unsigned long currentBroadcast;  // timestamp at current broadcast
/* Misc Items */
const int led = 13;           // on-board led of Arduino Yun
int duration = 0;             // duration to record for
  // Initialize Bridge
  Bridge.begin();
  // Initialize serial communications:
  // Initialize SD File System
    FileSystem.begin();
  // Initialize the on-board led as output and the pin connected
  // to the hall effect sensor as input:
  pinMode(led, OUTPUT);
  pinMode(hall_output, INPUT);
  // Wait for serial to be connected, remove this in the future
  while(!Serial);
  // Wait until connected to the Internet
  //while(!isConnectedToInternet());
  // Sync clock with NTP
  setClock();
  // Get time from Linino in Unix timestamp format
  epoch = timeInEpoch();
  lastBroadcast = epoch;
  Serial.println("Ready for broadcasting...");
  String dataString;
  dataString += "Date-Time, Pulse Count/";
  dataString += duration;
  dataString += " millsec";
  waitForPeak();
  if((calcCurrentTimestamp() - lastBroadcast) > broadcastInterval) {
    logData();
    sendAlert();
// Synchronize clock using NTP
void setClock() {
  Process p;
  Serial.println("Setting clock.");
  p.runShellCommand("ntpd -nqp 0.openwrt.pool.ntp.org");
  // Block until clock sync is completed
  while(p.running());
// Return timestamp of Linino
unsigned long timeInEpoch() {
  Process time;                   // process to run on Linuino
  char epochCharArray[12] = "";   // char array to be used for atol
  // Get UNIX timestamp
  time.begin("date");
  time.addParameter("+%s");
  time.run();
  // When execution is completed, store in charArray
  while (time.available() > 0) {
    millisAtEpoch = millis();
    time.readString().toCharArray(epochCharArray, 12);
  // Return long with timestamp
  return atol(epochCharArray);
// Return current timestamp, calculated by initial Linino's epoch + seconds past since then
unsigned long calcCurrentTimestamp() {
  return epoch + ((millis() - millisAtEpoch) / 1000);
// Wait for a peak. Turn the led on while hall effect output is 0V.
// Then turn led off and increase the number of peaks.
void waitForPeak() {
  while(digitalRead(hall_output) == HIGH);
  digitalWrite(led, HIGH);
  delay(10);  // small delay because a pass of the magnet might be counted as multiple peaks
  while(digitalRead(hall_output) == LOW);
  digitalWrite(led, LOW);
  peaks++;
void logData (String dataString){
  // open the file. Note that only one file can be open at a time,
  // so you have to close this one before opening another.
  // The FileSystem card is mounted at the following "/mnt/FileSystema1"
  File dataFile = FileSystem.open("/mnt/sd/WaterMon.csv", FILE_APPEND);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening WaterMon.csv");
// This function return a string with the time stamp
String getTimeStamp() {
  String result;
  Process time;
  // date is a command line utility to get the date and the time
  // in different formats depending on the additional parameter
  time.begin("date");
  time.addParameter("+%D-%T");  // parameters: D for the complete date mm/dd/yy
  //             T for the time hh:mm:ss
  time.run();  // run the command
  // read the output of the command
    char c = time.read();
    if (c != '\n')
      result += c;
  return result;
void sendAlert (){
The function declaration for logData() indicates that it requires a parameter of type String.
The call of logData() has no parameters. That causes the error message, which is correct because it is indeed erroneous to call that function with no parameters.
You say it works in another sketch? It shouldn't. Could you post that other sketch? There must be another explanation hidden in there.
I missed the fact that I did not include variable in the initial function call... thanks for pointing that out. Works fine now.
Thank you,
