too many arguments to function 'uint8_t shiftIn(uint8_t, uint8_t, uint8_t)'
i got this error today while trying to upload the code, can you help me find the wrong code??
thank you before
// send a command to the SHTx sensor
void sendCommandSHT(int command, int dataPin, int clockPin)
int ack;
// transmission start
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
digitalWrite(dataPin, HIGH);
digitalWrite(clockPin, HIGH);
digitalWrite(dataPin, LOW);
digitalWrite(clockPin, LOW);
// shift out the command (the 3 MSB are address and must be 000, the last 5 bits are the command)
shiftOut(dataPin, clockPin, MSBFIRST, command);
// verify we get the right ACK
pinMode(dataPin, INPUT);
ack = digitalRead(dataPin);
if (ack != LOW)
Serial.println("ACK error 0");
if (ack != HIGH)
Serial.println("ACK error 1");
// wait for the SHTx answer
void waitForResultSHT(int dataPin)
int ack;
for (int i = 0; i < 100; ++i)
delay(10);
if (ack == LOW)
if (ack == HIGH)
Serial.println("ACK error 2");
// get data from the SHTx sensor
int getData16SHT(int dataPin, int clockPin)
int val;
// get the MSB (most significant bits)
val = shiftIn(dataPin, clockPin, MSBFIRST, 8, 3);
val *= 256; // this is equivalent to val << 8;
// send the required ACK
// get the LSB (less significant bits)
val |= shiftIn(dataPin, clockPin, LSBFIRST, 8, 3);<<< this is error line
return val;
// skip CRC data from the SHTx sensor
void skipCrcSHT(int dataPin, int clockPin)
Please use code tags instead of quote tags.
You're passing five arguments to a function that only expects 3 arguments; shiftIn() reference.
What are you trying to achieve with the last two arguments?
it would have saved time if you posted the error
C:\stuff\SW\Arduino\_Others\ban\ban.ino: In function 'int getData16SHT(int, int)':
ban:52: error: too many arguments to function 'uint8_t shiftIn(uint8_t, uint8_t, uint8_t)'
looks like shiftIn() takes 3 arguments. you have 5
