On my MacBook Pro running Mac OS 10.7.5 the over-long menus show a little arrow at the top and/or bottom. Hovering the cursor on the arrow causes the menu to scroll. It works for Arduino 1.0.5 "Sketch -> Import library...", "File -> Sketchbook" and "File -> Examples" menus, all of which are taller than the screen.
Same problem on WinXP. (Took a while to duplicate my libraries and rename them so quantity exceeded my screen height. Afterwards I thought I could have reduced screen resolution ...) Incidentally, using the arrow-keys I could select any library in the list .. but I had to imagine how far down "below" the screen edge my cursor was.
I have the same problem with the IDE and had to start using the Enhanced IDE by eried to display all the libraries. I have tried everything to use the official IDE with no luck.
This is a common problem, and one I have looked at addressing in MPIDE. My current solution is to break the libraries and examples down into sub-menus, grouped by their location, or "class" - "core" libraries (.../libraries), "hardware specific" libraries (.../hardware/target/libraries), contributed libraries (.../sketchbook/libraries), etc.
It's something maybe Arduino should think about adopting in some form.
Also the sketchbook menu needs overhauling. On my experimental MPIDE version I have a maximum of 20 entries in the sketchbook menu, and at the top of the menu is a "more >" entry, which opens up another menu with 20 entries - again with its own "more >" entry. It can chain as many of those together as it needs, and with my sketchbook folder it needs a lot
Again something Arduino should think about implementing in some form...
majenko:
Irrespective of whether you're using Arduino, it would be sensible to adopt a directory structure that groups related sketches together into a logical hierarchy instead of dumping them into a flat directory. And, if you did this, you would find that the Arduino IDE presents the resulting directory structure via some nice walking menus - IMO this is much better than simply allowing the list to overflow onto 'more' pages and I recommend you follow that approach for the MPIDE you mention.
PeterH:
Oh yes. And it indeed that works. But Terry asked about the LIBRARIES folder, not sketches, and he writes:
terryking228:
And subfolders don't work for this as far as I can see...
