too many initializers for 'char [10]'
Hi all,
I have a problem with this array,
char speeds[10] = {"slow", "fast"};
If I change the number inside the in 2 or 3 or any other number, nothing changes.
With this variabile I must write in serial monitor, "slow" or "fast", for change speed of the motor, if I test this with a variable,
char slow = 's';
So it's work.
But, the problem is the IDE says "Too many initializers for char[10]", but it's not true.
You can only have one string there. You need two char arrays for two separate strings.
mirco9779x:
Hi all,
Looks like you want to declare two char arrays of length 5 each (including terminating null char).
  char speeds[2][5] = {"slow", "fast"};
jurs:
Ok, I solved, but now I have another problem, when I call the Array,
char command; (Out of Loop function)
char speeds[2][5] = {"slow", "fast"}; (Out of Loop function)
if (command == speeds[0]){ (Inside Loop function)
analogWrite(motor, 100);
IDE says me, "ISO C++ forbids comparison between pointer and integer [-fpermissive]".
char speeds[9] = {"slow" "fast"};
That isn’t how you compare strings. Google the strcmp function.
That's correct, it does.
command is an integer, speeds[0] is an array (aka pointer).
It makes no sense to compare a single letter to four letters.
Look at capturing a whole string, and then using strcmp
You can't compare a string like that. It's because it's an array of variables and you can only compare one variable at a time with ==. Use strcmp() instead.
Did a post disappear?
Ok, I solved, I add "[5]", after "[0]" and now it's work. Thanks to all.
if (command == speeds[0][5]){
Delta_G:
Yes, it did, but it is back now.
mirco9779x:
No, that's not a solution, but it is a good demonstration of why you should use code tags.
AWOL:
No, that’s not a solution, but it is a good demonstration of why you should use code tags.
Why thats not a solution?
Because like a lot of people say, that's not how you compare a string. I may compile but it certainly doesn't work :wink:
mirco9779x:
Looks like you want 'command' to be a string, too.
Perhaps:
char command[5];
But why do you want to use strings for all variables? Atmega controllers have very little RAM and each string will use some amount. It's nonsense to waste RAM for huge amounts of strings in a program.
What about using 'speaking constant names' with an enumeration (enum), you can assign to a variable?
  enum {SLOW, FAST}; // create some 'speaking constant names', SLOW=0, FAST=1
  char speedStr[2][5] = {"slow", "fast"};
  byte command=SLOW;
  Serial.println(speedStr[command]);
  if (command==SLOW) analogWrite(motor, 100);
  else analogWrite(motor, 500);
BTW: If you really want to deal with different strings (nullterminated strings) and compare them, the comparison is NOT done with numeric operator "==", but by calling the 'strcmp()' function.
jurs:
Perhaps:
char command[5];
  byte command=SLOW;
Ok, I'm a beginner in C++ and I don't know what is "enum" and "byte" variables (if is variables).
So you only want to check to see if command is equal to a null character? (speeds[0][5] is the null terminator on the end of "slow") This would be easier in that case:
 if (command == 0)
Delta_G:
No, 5 is an overshoot of the array :wink: So it's probably the first entery of the next part. So speeds[1][0]
septillion:
No, 5 is an overshoot of the array :wink: So it’s probably the first entery of the next part. So speeds[1][0]
You are correct sir. My bad.
septillion:
But the [ 1 ] and [ 0 ], what is?
1 is the second object of the array when I call them?
Is the first ([ 1 ]) or second ([ 0 ]) for call objects ?
