I have a 12V/350mA bipolar stepper motor from Adafruit: http://www.adafruit.com/products/324
I have a Arduino motor shield attached on top of the Arduino; this motor shield uses the LM298 driver, which can output 2A max per channel, according to data sheet. However, due to the huge mass (20 in Al motor shaft + attached PCBs; very heavy stuff) on top of the motor shaft, the motor is no longer turning, and I have to slowly push it w/ my hand to get it to turn step by step. My power supply (from Agilent) is 24V/0.5A. Do I need a larger power supply? All I'm doing is trying to make motor spin back+forth using the Stepper.h library. How do I make this motor turn? Do I need a motor w/ a higher current rating (up to 2A)?
Edit: I have 1 more question-- is there any way to adjust the acceleration of the bipolar stepper motor on the Arduino code? I know I can adjust speed using "myStepper.setSpeed(200)", where 200 = 200 rpm.
Does that mean that it runs, and keeps going, after you give it an "assist"?
If so, that's a clue.
Going from a body at rest to a body in motion takes a lot of work.
A better-rated supply (or some SLA batteries) may prove beneficial.
Not quite-- it's still at rest no matter what I do. I've tried a different power supply (from 24V to 32V) for the motor. I've tried pushing it, but it's still at rest. I know it's trying to move, because I see the 4 LED lights at the 4 outputs are flashing and there's a lot of audible motor noise.
Clown_of_God:
