I am using a Nano to run a door control system including a pinpad, a 1602 LCD run by shift register (595) and an RGB LED for bling. I am not using the Red on the LED as it may have popped. controlling the access is one of those optically isolated relays from eBay. I have also added an output for another relay for some lights to be installed later.
my main problem is that my LEDS arent working - the Green and Blue Pins. I know the LED is ok I have tested it with a simpler code.
EDIT: should mention that the RGB is a common positive (Anode?) with a 1k res between it and 5V
Is it being blocked somewhere? Can anybody see anything wrong with my code? or do I have too much attached drawing current?
also first post so sorry if this is in the wrong spot.
Cheers in advance for any help.
here is my code:
#include <LiquidCrystal_SR.h>
#include <LCD.h>
#include <Password.h>
#include <Wire.h>
#include <OnewireKeypad.h>
//Setup LCD
// setting the pins for the shift register Data, Clock, Enable
LiquidCrystal_SR lcd(2, 3, 4);
//Setup Keypad
char KEYS[] =
'1', '2', '3',
'4', '5', '6',
'7', '8', '9',
'*', '0', '#',
OnewireKeypad <Print, 12> PadS(Serial, KEYS, 4, 3, A1, 4700, 1000);
//Get our numbers right
int Blue = 11;
int Green = 12;
int Blight = 9;
int Relay = 7;
int Reset = 8;
int Lights = 6;
//setup for using millis timers
unsigned long MagTime;
unsigned long LtTime;
unsigned long EvalTime;
boolean Magnet = false;
boolean Light = false;
boolean Evaluated = false;
//set password
Password password = Password( "2501" );
Password LitUp = Password( "0" );
byte maxLength = 4; // how long the password will be
byte currentLength = 0;
Serial.begin(9600);// for input prepad, and output diag
//Reset needs to be set before anything else
digitalWrite(Reset, HIGH);
pinMode(Reset, OUTPUT);
//Set up the pins
pinMode(Blue, OUTPUT);
pinMode(Green, OUTPUT);
pinMode(Blight, OUTPUT);
pinMode(Relay, OUTPUT);
pinMode(Lights, OUTPUT);
//make sure pins in correct state to start
digitalWrite(Lights, HIGH);
digitalWrite(Relay, HIGH);
digitalWrite(Blue, LOW);
digitalWrite(Green, HIGH);
digitalWrite(Blight, HIGH);
//Begin the boot
lcd.begin(16, 2);
BlueFlash();
lcd.setCursor(3, 0);
lcd.print("Code then #");//info for the uninformed
lcd.setCursor(3, 1);
lcd.print("* to Reset");
delay(1500);
digitalWrite(Blight, LOW);
lcd.clear();
//using OneWireKeypad to capture entries. Library is easy to find
if (PadS.Getkey())
char keyP = PadS.Getkey();
PadS.SetHoldTime(150);
if (PadS.Key_State() == 3)
switch (keyP)
case '*': //reset entry if made a mistake
ResetUnit();
case '#': //evaluate password
DoorCheck();
default: //append any keypress that is not a '*' nor a '#' to the currently guessed password.
password.append(keyP);
LitUp.append(keyP);
currentLength++;
//Print some feedback.
Serial.print("Enter password: "); // debug
lcd.print("Enter Code:");
lcd.setCursor(6, 1);
for (byte i = 0; i < currentLength; i++)
{ //adding * for each entry
Serial.print('*');
lcd.print("*");
Serial.println("Entry");
if (currentLength > maxLength) // if more than the chosen password length is entered
Serial.print("Overflow"); //debug
lcd.clear();
digitalWrite(Blue, HIGH);
lcd.setCursor(4, 0);
lcd.print("Too many");
lcd.setCursor(4, 1);
lcd.print("entries!");
lcd.clear();
lcd.print("Resetting");
ResetUnit();
delay(800);
lcd.clear();
TimerCheck();
// Flash the led during an event
void BlueFlash()
for (int q = 0; q < 2; q++)
delay(150);
delay(150);
// Check the passwords
void DoorCheck()
lcd.clear();
Serial.print("Evaluated"); //debug
if (LitUp.evaluate()) // if light code entered
BlueFlash();
lcd.clear();
lcd.print("Let There");
lcd.print("Be Light");
digitalWrite(Lights, LOW);
LtTime = millis();
Light = !Light;
currentLength = 0;
if (password.evaluate()) //if entry code entered
digitalWrite(Green, LOW);
lcd.print("Correct!");
Serial.print("Yes"); // debug
digitalWrite(Relay, LOW); // open sesame
currentLength = 0;
Magnet = !Magnet;
MagTime = millis();
//record that # has been pressed
EvalTime = millis();
Evaluated = !Evaluated;
//right or wrong clear password arrays
password.reset();
LitUp.reset();
void TimerCheck()
// turn the magnet back on after 1 sec
if (Magnet && millis() - MagTime >= 1000)
Magnet = !Magnet;
// lights stay on for five minutes
if (Light && millis() - LtTime >= 300000)
digitalWrite(Light, HIGH);
Light = !Light;
//turn off message after 5 secs
if (Evaluated && (millis() - EvalTime > 3000))
lcd.clear();
//reset the nano when things get weird
void ResetUnit()
digitalWrite(Blight, HIGH); // Backlight on
lcd.setCursor(2, 1);
lcd.print("Please Wait");
BlueFlash();
Serial.print("reset"); //debug
delay(200);
digitalWrite(Reset, LOW);
Dolok2501.timertweak.V1.ino (4.89 KB)
