請問前輩按鈕程式EButton.h中的時間函數可以調用嗎
#include "Arduino.h"
// ------- Specify not required features before including the EButton.h --------
//#define EBUTTON_SUPPORT_TRANSITION_DISABLED
//#define EBUTTON_SUPPORT_EACH_CLICK_DISABLED
//#define EBUTTON_SUPPORT_DONE_CLICKING_DISABLED
//#define EBUTTON_SUPPORT_SINGLE_AND_DOUBLE_CLICKS_DISABLED
//#define EBUTTON_SUPPORT_LONG_PRESS_START_DISABLED
//#define EBUTTON_SUPPORT_LONG_PRESS_DURING_DISABLED
#include "EButton.h"
EButton button(2);
// ------- Printing event details --------
void print(EButton &btn) {
Serial.print(F(" [pressed="));
Serial.print(btn.isButtonPressed());
Serial.print(F(", clicks="));
Serial.print(btn.getClicks());
Serial.print(F(", startTime="));
Serial.print(btn.getStartTime());
Serial.print(F(", prevTransitionTime="));
Serial.print(btn.getPrevTransitionTime());
Serial.println(F("]"));
// ------- Handler methods --------
void transitionHandler(EButton &btn) {
Serial.print(F("TRANSITION"));
print(btn);
void eachClickHandler(EButton &btn) {
Serial.print(F("EACH_CLICK"));
print(btn);
void singleClickHandler(EButton &btn) {
Serial.print(F("SINGLE_CLICK"));
print(btn);
void doubleClickHandler(EButton &btn) {
Serial.print(F("DOUBLE_CLICK"));
print(btn);
void doneClickingHandler(EButton &btn) {
Serial.print(F("DONE_CLICKING"));
print(btn);
void pressStartHandler(EButton &btn) {
Serial.print(F("PRESS_START"));
print(btn);
unsigned long t;
void duringPressHandler(EButton &btn) {
if ((unsigned long) (millis() - t) > 1000) {
// Print once a second
Serial.print(F("DURING_PRESS"));
print(btn);
t = millis();
void pressEndHandler(EButton &btn) {
Serial.print(F("PRESS_END"));
print(btn);
// ------- Setting up the driver and registering listeners --------
Serial.println(F("\nEButton Demo"));
button.setDebounceTime(EBUTTON_DEFAULT_DEBOUNCE); // not required if using default
button.setClickTime(EBUTTON_DEFAULT_CLICK); // not required if using default
button.setLongPressTime(EBUTTON_DEFAULT_LONG_PRESS); // not required if using default
button.attachTransition(transitionHandler);
button.attachEachClick(eachClickHandler);
button.attachDoneClicking(doneClickingHandler);
button.attachSingleClick(singleClickHandler);
button.attachDoubleClick(doubleClickHandler);
button.attachLongPressStart(pressStartHandler);
button.attachDuringLongPress(duringPressHandler);
button.attachLongPressEnd(pressEndHandler);
// Ticking the driver in a loop
button. Tick();
