Howdy,
I'm trying to get information back to the web browser via websockets. I have been able to do it by requesting it every time I send a message to the server. The problem is it is old info from the last time it sent a string.
I'm not very smart with python and even looked how to put an "if serial is available, write_message to client" but could not get it down. Any ideas or anyone who has been able to get real time from the arduino to the browser?
Here's my python/tornado code:
import tornado.ioloop
import tornado.web
import tornado.websocket
import serial
from tornado.options import define, options, parse_command_line
define("port", default=8888, help="run on the given port", type=int)
clients = dict()
ser = serial.Serial('/dev/ttyATH0', 115200, timeout=0)
class WebSocketHandler(tornado.websocket.WebSocketHandler):
print "Waiting for Connection..."
def check_origin(self, origin):
return True
def open(self):
print "Websocket Connection Open"
ser.flushInput()
ser.flushOutput()
ser.write("thdfONx")
def on_message(self, message):
dato_1 = str(message)
print (dato_1)
ser.write(dato_1)
dato_2 = str(ser.readline())
print (dato_2)
self.write_message(dato_2)
ser.flushInput()
ser.flushOutput()
def on_close(self):
print "WebSocket Connection Closed"
ser.flushInput()
ser.flushOutput()
ser.write("thdfOFFx")
app = tornado.web.Application([
(r'/', WebSocketHandler),
if __name__ == '__main__':
parse_command_line()
app.listen(options.port)
tornado.ioloop.IOLoop.instance().start()
Thanks in advance!
