Torque formula for stepper
Hi
I have a question mostly related to mathematics or physics.
I would like to use a stepper motor to move a 2 meter and 10kg aluminum bar.
Like some kind of clock but where the clock hand is 2 meter and 10gkg.
I'm looking for the formula to calculate the torque in order to choose the right motor and gearbox.
Do anyone have an idea on it?
Thank you
That will be quite the load !
Is it going to be on a vertical plane or horizontal ?
Is there going to be any form of counter balance ?
Will there be any runner support at the end ?
Many steppers include the max load in the specifications so using that and adding a safety margin would be the simplest calculation. (+10%)
I suspect a minimum of a NEMA 24 with a suitable rating would be in order.
This may also have a bearing on the driver you need to employ too.
Some more tech details may help ?
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Hi, and thank you for your answer.
It is going to be vertical and without any counter balance or anything at any end.
The torque specifications of the motors are in Newton/meter, so I'm looking for some kind of formula to calculate this torque.
From what I understand Nema24 only specifies the size of the frontplate of the motor not really any torque
Thank-you
Rémi
If you have a uniform 2 metre horizontal bar that weighs 10kg and is hinged at one end then you can assume that the weight is concentrated at the mid point and the torque at the hinge would be 10kg m or about 100 Nm
At other angles (assuming the axis is horizontal) the torque will be less.
I recommend a strict slimming regime for the bar.
...R
yes it does indicate the front plate size (mounting) but there are often different body lengths and the longer ones usually indicate that it is capable of more torque.
See this spec sheet for a quick guide
Notice the spec in Nm varies with body length.
You can also get them with different shafts and dual shafts which would allow you to add a counter balance on the back side to reduce the torque needed.
Speed of rotation can also play a large factor in selection too with an unequal load applied.
This may mean moving up to a larger face plate mounting (NEMA 34 etc) to account for the extra load especially in a vertical plane at higher RPM's
Holding position would almost certainly involve a better quality driver and suitable PSU.
remdem:
Hi
I’m looking for the formula to calculate the torque in order to choose the right motor and gearbox.
Thank you
Alas steppers are too complex for a simple formula to apply. The best you get are the graphs of
dynamic torque v. speed in the datasheet - there will be several for different supply voltages.
Typically these are only given for the motors nominal max current rating. Reducing current will
reduce torque, but don’t assume its very linear effect.
Resonance effects can strongly affect torque performance in steppers and this is load-dependent too,
so you always have to check a given setup and take the performance graphs with a pinch of salt.
In general microstepping helps by reducing resonance, and torque always drops with speed in
any stepper. High supply voltage improves torque at speed, but has no effect on the hold-in
torque at stationary.
This all assumes the stepper is driven properly with a stepper driver that controls current and
can handle the supply voltage.
remdem:
No no no!
Torque is the PRODUCT of radius and force, its measured in N-m (not N/m).
Thank you all for your answers, this is really helpfull.
As you seem to know the subject quite well, I have another quick question.
If I use a 10:1 gearbox, will I get 10 times more torque, and a 50:1 gearbox, 50 times more torque, or is this not so simple?
Thank-you again.
Rémi
In theory yes, in practice you lose power to friction so that, particularly when moving, the output
torque will be somewhat less, but yes gears trade torque for speed. They are just a kind of lever.
Thank you very much MarkT!
