Hey,
I am having a little problem that I just can't seem to fix or find any information on. I am reading from 8 sensors and saving the data in a 2D array. Then I am doing some calculations on the data. My problem is that when I do my smoothing operation I get a wierd jump in the smoothed curve. It does not happen in the first round of the loop, but in all the others. The jump is one position long in the first point and 8 positions long at point 126. I appreciate any help I can get.
Thanks!
#include <Controllino.h> // Usage of CONTROLLINO library allows you to use CONTROLLINO_xx aliases in your sketch. //
volatile int count = 0; //sets the variable count to zero. A variable should be declared volatile whenever its value
volatile int countzero = 0; //can be changed by something beyond the control of the code section in which it appears, such as a concurrently executing
//thread. In the Arduino, the only place that this is likely to occur is in sections of code associated with interrupts, called an interrupt service routine
int switchstate = 0;
int Gauss = 0;
int testArray[8][365]; //defines array for hall sensor 1
int result = 1; //Result for strength 0 = ok, 1 =NOK
int result1 = 1; //Result for angel error 0 for OK 1 for NOK
int approved = 1;
int tt = 0;
Serial.begin(9600); //Sets the data rate in bits per second (baud) for serial data transmission
pinMode(CONTROLLINO_R0, OUTPUT); //Configures the specified pin to behave either as an input or an output
//R0 is a relay that Will start the motor
pinMode(CONTROLLINO_D0, OUTPUT); //output signal to robot if parts are ok
pinMode(CONTROLLINO_D1, OUTPUT); //output signal to robot parts NOK
pinMode(CONTROLLINO_D2, OUTPUT); //Temperary output for test
pinMode(CONTROLLINO_IN0, INPUT); //IN0 is an interupt and will read the pulse from the refernce point
pinMode(CONTROLLINO_A0, INPUT); //pin for the start switch
pinMode(CONTROLLINO_A1, INPUT); //pin for the hall sensor 1
pinMode(CONTROLLINO_A2, INPUT); //pin for hall sensor 2
pinMode(CONTROLLINO_A3, INPUT); //pin for hall sensor 3
pinMode(CONTROLLINO_A4, INPUT); //pin for hall sensor 4
pinMode(CONTROLLINO_A10, INPUT); //pin for hall sensor 5
pinMode(CONTROLLINO_A9, INPUT); //pin for hall sensor 6
pinMode(CONTROLLINO_A7, INPUT); //pin for hall sensor 7
pinMode(CONTROLLINO_A8, INPUT); //pin for hall sensor 8
//allows external interrupts
attachInterrupt(digitalPinToInterrupt(CONTROLLINO_IN0), zero, RISING); //attachInterrupt(digitalPinToInterrupt(pin), ISR, mode) (recommended) pin: the Arduino pin number.
//ISR: the ISR to call when the. mode: defines when the interrupt should be triggered. interrupt occurs
switchstate = digitalRead(CONTROLLINO_A0);
result = 1;
result1 = 1;
if (switchstate == HIGH) //Read from robot that it is time to start a measruement
digitalWrite(CONTROLLINO_R0, HIGH); //Start motor
delay(3500);
for (int work = 0; work < 8; work++) //Evaluation loop
tt += 1;
approved = Eval1();
if (approved == 1)
work = 0;
//Serial.println(approved);
if (approved == 0)
//digitalWrite(CONTROLLINO_D0, HIGH);
Serial.println("OK");
//digitalWrite(CONTROLLINO_D1, HIGH);
Serial.println("NOK");
delay(30);
countzero = 0;
tt = 0;
//**********************************************************************Function: Count zero pulse************************************************************************
void zero()
countzero += 1; //add one to the count of zero pulses
int x = countzero - 1;
testArray[0][x] = analogRead(CONTROLLINO_A1) ;
testArray[1][x] = analogRead(CONTROLLINO_A2) ;
testArray[2][x] = analogRead(CONTROLLINO_A3) ;
testArray[3][x] = analogRead(CONTROLLINO_A4) ;
testArray[4][x] = analogRead(CONTROLLINO_A10);
testArray[5][x] = analogRead(CONTROLLINO_A7) ;
testArray[6][x] = analogRead(CONTROLLINO_A8) ;
testArray[7][x] = analogRead(CONTROLLINO_A9) ;
if (x == 360)
digitalWrite(CONTROLLINO_R0, LOW);
for (int i = 0; i < 365; i++) {
Serial.println(testArray[0][i]);
Serial.println("done testArray");
//*************************************************************************Function: Evaluate testArray*********************************************************
int Eval1()
float calcArray[180];
float tempA = 0;
float maxMin = 0;
float C = 0.00;
for (int ty = 0; ty < 180; ty++)
calcArray[ty] = 0.00;
//Serial.print(tt);
// Serial.println("tt");
//--------------------------------------------------------------------------------Smooth the values---------------------------------
for (int t = 0; t < 180; t++)
if (tt == 1) //calibration for sensor placement
C = 1.35;
if (tt == 2)
C = 2.31;
if (tt == 3)
C = 3.15;
if (tt == 4)
C = 1.00;
if (tt == 5)
C = 1.34;
if (tt == 6)
C = 1.00;
if (tt == 7)
C = 1.34;
if (tt == 8)
C = 1.52;
calcArray[t] = ((testArray[tt - 1][(t + 2) * 2] + testArray[tt - 1][((t + 2) * 2) + 1]) / 2.00) * C;
//delay(50);
// for (int i = 0; i < 180; i++) {
// Serial.println(calcArray[i]);
//Serial.println("done smoooth");
//-----------------------------------------------------------------------find max, min and amplitude--------------------------------
float maxTemp = calcArray[0]; //max value place holder
float minTemp = calcArray[0]; //min value place holder
for (int u = 1; u < 180; u++)
if (calcArray[u] > maxTemp) //find the maximum in the array.
maxTemp = calcArray[u];
if (calcArray[u] < minTemp) //find the minimum in the array.
minTemp = calcArray[u];
maxMin = (maxTemp - minTemp) / 2.00; //evaluate amplitude
//Serial.println(maxMin);
//Serial.println("next");
//-----------------------------------------------------------------------convert to cos'---------------------------------------
for (int v = 0; v < 180; v++)
calcArray[v] = (calcArray[v] - (maxTemp - maxMin)) / maxMin;
// Serial.println("Done cos'");
//---------------------------------------------------------------------arctan2 plus conversion to degrees-----------------------------------------
float calcArraycopy[44];
for (int hi = 0; hi < 44; hi++)
calcArraycopy[hi] = calcArray[hi];
//for (int i = 0; i < 44; i++)
// Serial.println(calcArraycopy[i]);
//Serial.println("done angle");
for (int w = 0; w < 180; w++)
int nn = w + 44;
if (nn > 179)
calcArray[w] = atan2(calcArray[w], calcArraycopy[w - 136]) * 180.00 / 3.1415;
calcArray[w] = atan2(calcArray[w], calcArray[nn]) * 180.00 / 3.1415;
//for (int i = 0; i < 180; i++) {
//Serial.println(calcArray[i]);
//----------------------------------------------------------------------shift array so that 180 degrees is first--------------------------------------------------------------------
for (int z = 1; z < 180; z++)
if (calcArray[0] > -178.50)
float temp = calcArray[0]; // save x[0] in temporary
for (int from = 1; from < 180; from++) // shift remaining values to the front of the array
{ int to = from - 1;
calcArray[to] = calcArray[from];
calcArray[179] = temp; // put x[0] saved in temp into last entry
//Serial.println("done shift");
//-------------------------------------------------------------------------check delta angle------------------------------------------------------------------------
tempA = 0;
for (int pp = 0; pp < 180; pp++)
float delta = calcArray[pp] - (-180.00 + (pp * 2));
if (abs(delta) > tempA)
tempA = abs(delta);
//Serial.println(tempA);
// Serial.println("done");
//--------------------------------------------------------------------------Ok eller NOK parts----------------------------------------------------------------
if (maxMin < 15) //part not ok
// Serial.println(maxMin);
result = 1;
else {
result = 0;
if (tempA > 400.00) //part not ok
result1 = 1;
result1 = 0;
if (result == 1 || result1 == 1)
return (1);
return (0);
