Total Newb - Want to make time delay vacuum release system
+1, totally doable unless you all thumbs.
And I second the idea of playing with the code separately from getting the relays or whatever into the picture.
Doesn't matter which you do first, just do the two parts alone
  • get some software printing plausible actions to be taken with the right timing
  • rig some relays and see that you can make them click, and that they can control your external components
For timing a simulation, you can always use shorter times, so you don't have to wait around twenty minutes to see that it did work - 1 minute would prove it, and trust me, will still be agonizing enough to sit through as you test. :expressionless:
then putting them together and you done.
Speaking of simulation, you can do a bunch of progress without any hardware, check out wokwi.com, it is really very convenient for testing little hacks and experimenting.
a7
