Total newbie looking for advice for DC voltmeter/ammeter
Hi everyone!
I'm a total newbie to Arduino and I'm starting my first Arduino project and I figured, meh, why make it easy?
I'm building a electric mini chopper that will be powered be a 48v 12ah battery pack. My controller can draw up to 200 amps max and I want to make a "fuel gauge" that shows both volts and amps.
Just to clarify, a fully charged 48v pack is actually around 57 -58 volts, so I want the voltmeter to read up to 60v. I would like the ammeter to read up to 200a if possible. I do understand that I will need a good quality shunt for something like this.
I've found a couple of post on different website on how to make individual voltmeters and ammeters, but I haven't found any that combine the two.
I'm planning to follow this tutorial to make the speedometer/tachometer:
So I would like to use the same display if possible.
I have "OK" coding skills in a couple of different languages, (I put the OK in parenthesis because my son is a developer for Openstack SDN and he laughs at my code! :wink: ), so I'm not afraid to approach this project as a beginner.
Does anyone have any suggestions?
Thanks
zog
I think you should make it easy and start with a simple project .
The problems you will have are any speed controller will be chopping the power supply and you will not get a steady, easily measured current . There will be a problem with measuring voltage and current - thinking of how you wire it up ( common 0v line ) . Any shunt will limit the motor current in a low voltage hi current circuit and you will need to amplify the signal. All this stuff adds weight- just measure the pack voltage and make do with that ( most controllers include that anyway) .
There are plenty of non-invasive ways of measuring current that don’t require a shunt. Have a look for “non-invasive current sensors”. Since many of them are designed for automotive use 200A DC is not a problem.
But I wouldn’t have anything to do with that “instructables” thing. There are many better ways of making a speedometer.
Steve
Do you have any filter caps or flyback diodes across the motor ?
The Arduino has multiple analog inputs. :wink:
It's actually easier to measure high current. A hall-effect current sensor is probably the way to go. If you use a shunt, it has to go on ground-side, because the Arduino can only measure voltage referenced to (its) ground. And hopefully, you know how to calculate power dissipation in the shunt.
For voltage, the [u]Analog Read Voltage Example[/u] will get you started. You'll need a voltage divider (2 resistors) and you'll have to scale the readings appropriately. And, I'd recommend a couple of [u]over voltage/reverse voltage protection diodes[/u] in case of unexpected spikes from the motor or charger.
Sounds like the OP already has a controller, all that is needed is a battery voltage and load current monitor.
Tom... :slight_smile:
slipstick:
There are plenty of non-invasive ways of measuring current that don't require a shunt. Have a look for "non-invasive current sensors". Since many of them are designed for automotive use 200A DC is not a problem.
Like this?
https://www.ebay.com/itm/50A-100A-150A-200A-Bi-Uni-AC-DC-Current-Sensor-Module-arduino-compatible-/111689533182?_trksid=p2385738.m2548.l4275
slipstick:
But I wouldn't have anything to do with that "instructables" thing. There are many better ways of making a speedometer.
Do you have any links to point me in the right direction?
raschemmel:
No, the motor is a DC brushed industrial permanent magnet motor. It connects tho the battery and controller like this:
DVDdoug:
LOL, not yet, but that's what Google is for! (sigh, What happened to the old days when you could stop learning as soon as you left university? :wink:)
DVDdoug:
Thanks for the links and pointing me in the right direction! I'll be sure to post my results when I get everything sorted out.
Thanks everyone!
