Touch LCD Gamer
I’m new to Arduino and would like some advice.
I’d like to make a touchpad device with functions to assist gamers such as rapid fire, key macros & binding etc.
I’ve got the Arduino starter set and the “Maplin touch LCD shield for arduino”
The screen is 320 x 240 16 bit colour with touch and microSD built in.
The extent of the hardware side is simply attaching the shield to the Arduino and connecting it via USB so no problem there.
I’m using a sample program to test the device but TouchScreen.h isn’t being found during compiling despite me adding the libraries. Any ideas why this isn’t getting found?
// Learning the basics of adafruits TFT LCD Touch
// adafruit’s 2.8" TFT Touch Screen 16bit color 320x240 pixels
// more info at 2.8" TFT Touchscreen - 320x240 pixels in 16 bit color
// tested using Arduino IDE 0022 and code base from here GitHub - adafruit/TFTLCD-Library: Arduino library for 8-bit TFT LCDs such as ILI9325, ILI9328, etc
// Code by Nathan@sobisource.com 3/5/2012
#include <Adafruit_TFTLCD.h>
#include <Adafruit_GFX.h>
#include <TouchScreen.h>
/* For the 8 data pins:
Duemilanove/Diecimila/UNO/etc ('168 and '328 chips) microcontoller:
D0 connects to digital 8
D1 connects to digital 9
D2 connects to digital 2
D3 connects to digital 3
D4 connects to digital 4
D5 connects to digital 5
D6 connects to digital 6
D7 connects to digital 7
For Mega’s use pins 22 thru 29 (on the double header at the end)
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // you can also just connect RESET to the arduino RESET pin. *if so just //comment line out
#define YP A3 // must be an analog pin, use “An” notation! A1 for shield
#define XM A2 // must be an analog pin, use “An” notation! A2 for shield
#define YM 9 // can be a digital pin-----uno=9 mega=23 7 for shield
#define XP 8 // can be a digital pin-----uno=8 mega=22 6 for shield
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we’re using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
// Color definitions - in 5:6:5
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
//–End of preSetup-------------------------------------------------------------------
//–start of setup-=-=-=–=—=-=–=-=—=-=—
void setup(void) {
Serial.begin(9600); //This turns on serial monitor
tft.reset(); //clears LCD Ram
digitalWrite(35, HIGH); //on mega 35 I use this for backlight. pin 10 for Shield i think… or //comment out and run backlight pin to 5v
// All this idenifies which LCD driver chip your using and tells Ada’s GFX LIB’s
uint16_t identifier = tft.readID();
if(identifier == 0x9325) {
progmemPrintln(PSTR(“Found ILI9325 LCD driver”));
} else if(identifier == 0x9328) {
progmemPrintln(PSTR(“Found ILI9328 LCD driver”));
} else if(identifier == 0x7575) {
progmemPrintln(PSTR(“Found HX8347G LCD driver”));
progmemPrint(PSTR("Unknown LCD driver chip: "));
Serial.println(identifier, HEX);
Serial.println(identifier);
return;
tft.begin(identifier); // this returns the above results. below you can see how I replaced all this once i know which one I have…
//tft.begin(0x9328); //<—Here I bypassed the above. cause I already checked…
tft.setRotation(3); // 3=landscape mode -w- row pins on right…
tft.fillScreen(BLACK); //Set’s LCD Back Ground as Black
//=-=–Button 1=-=-=-=-=–=–==-=–=-=-=-=-=-=–=-=-=-=–=
tft.fillRect(25, 70, 100, 75, BLUE); //our Rectangle box for Button 1 ( x, y, w, h, color)
tft.setTextSize(2); //Sets all text font size till called again (Fontsize 1-5) defualt is “1”
tft.setTextColor(WHITE); //Sets all text color till called again
tft.setCursor(30, 100); //sets cursor to start writing text from… (x, y)
tft.println(“Button 1”); // Text string to write on lcd
//==-=-=-Button 2=-=-=-=-=-=–=–=–=-=-=–=–=–=-=-==-=-=-
tft.fillRect(170, 70, 100, 75, BLUE); // Button 2 box
//Since were using same text size we dont need to call tft.setTextSize() again…
tft.setTextColor(RED); //setting Text color from WHITE to RED
tft.setCursor(175, 100); //changing cursor from last button location to button 2 location
tft.println(“Button 2”); //button 2 text
}// End of setup
#define MINPRESSURE 10 //check for any touch 0 would mostly be too senitive.
#define MAXPRESSURE 1000
//–Start of loop-----------------------------------
void loop(){
Point p = ts.getPoint(); //checks touch x/y min-max
// if you’re sharing pins, you’ll need to fix the directions of the touchscreen pins!
//pinMode(XP, OUTPUT); //normally not needed…when used as defualt setup…
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
//pinMode(YM, OUTPUT); //normally not needed…when used as defualt setup…
// turn from 0->1023 to tft.width
p.x = map(p.x, TS_MINX, TS_MAXX, 0, 240);//default is (240, 0) [default puts touch cord. 0=x/y upper right.
p.y = map(p.y, TS_MINY, TS_MAXY, 0, 320);//default is (320, 0) [I change these cause i like 0=xy bottom left.
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) { //checks IF theres any touch action then continues
/* //checks touch x/y if pressed and sends them your serial monitor
if (p.z > ts.pressureThreshhold) {
Serial.print("Y = “); Serial.print(p.y);
Serial.print(”\tX = “); Serial.print(p.x); // \t= space
Serial.print(”\tPressure = "); Serial.println(p.z);
delay(800); //just to slow down the readings a little bit
if (p.y > 28 && p.y < 128 && p.x > 88 && p.x < 166) { //looks for touch within x/y box area of button 1
// if touch detected within box. what code to carry out goes next…
tft.setTextSize(3);
tft.setCursor(12, 213);
tft.println(“button 1 Pressed”); //writes the text “button 1 pressed”
delay(1000); //length of time to display message
//Using fill Rectangle to clear message
tft.fillRect(12, 213, 290, 21, GREEN); //Shows the wipe area
delay(1000); //time between fills so you can see it happen
tft.fillRect(12, 213, 290, 21, BLACK); //fills text area with bkgrd color to clear message
if (p.y > 177 && p.y < 276 && p.x > 90 && p.x < 167) { //looks for touch within x/y box area
tft.setTextSize(3);
tft.println(“button 2 Pressed”); //writes the text “button 1 pressed”
//write the same letters again using backgrnd colors to clear message
tft.setTextColor(BLACK);
}// end of loop
Once I get this issue sorted I shouldn’t have too many problems but I’d like to know if there’s some reason why any of these functions wouldn’t be impossible:
Mouse rapidfire
Keyboard macros/bindings
Using the device as removable storage (think 2gb is max though)
Running additional programs from the SD
Attaching a battery and using the device as a portable media device (photo, video, mp3)
Using the touchscreen as a secondary display (bandwidth issues maybe?) If this is an issue could using B&W or low res be a solution?
Having a small button to switch between functions.
The shield uses every pin except for the 2 on each side closest to the USB, anything else I can use those pins for?
