touch lib no Y axis.
Guys, could one of you mega minds please check what the hell is wrong in here.
Interfacing Due with touch without controller, getting X and Z but Y is all the time 0.
// Touch screen library with X Y and Z (pressure) readings as well
// as oversampling to avoid 'bouncing'
// This demo code returns raw readings, public domain
#include <stdint.h>
#include "TouchScreen.h"
// These are the pins for the shield!
#define YP A4  // must be an analog pin, use "An" notation!
#define XM A1  // must be an analog pin, use "An" notation!
#define YM 12   // can be a digital pin
#define XP 11   // can be a digital pin
#define MINPRESSURE 10
#define MAXPRESSURE 1000
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
void setup(void) {
void loop(void) {
  // a point object holds x y and z coordinates
  TSPoint p = ts.getPoint();
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
     Serial.print("X = "); Serial.print(p.x);
     Serial.print("\tY = "); Serial.print(p.y);
     Serial.print("\tPressure = "); Serial.println(p.z);
.cpp and .h file attached below.
Thanks for any advice.
TouchScreen.cpp (8 KB)
TouchScreen.h (1.09 KB)
Bump
