Hi there, I'm trying to control a set of LEDs with my ipod touch, using an app called TouchOSC. I want to be able to dim each LED individually from the iPod. Basically, the app on the iPod sends a value to processing, on my Mac, which then sends that value onto the arduino through serial. The arduino is then supposed to read the serial, figure out which LED it has to dim, and then dim it to that level.
I can turn each LED on and off individually using a different set of sketches, but I'm having trouble with this dimming one. I can see that processing is receiving the number from the iPod properly, because it prints it properly, but it doesn't dim the lights on the arduino.
Any help would be greatly appreciated!
(P.S. the app that creates the TouchOSC templates is called TouchOSC Editor. I've tried to attach the templates I've created/am using, hopefully they upload properly)
Arduino code for the dimmer:
int LBlue = 3;
int LGreen = 5;
int LRed = 6;
int RBlue = 11;
int RGreen = 10;
int RRed = 9;
int message = 0;
int number = -1;
int value = 0;
String bla = "";
int serReadInt()
int i, serAva; // i is a counter, serAva hold number of serial available
char inputBytes [7]; // Array hold input bytes
char * inputBytesPtr = &inputBytes[0]; // Pointer to the first element of the array
if (Serial.available()>0) // Check to see if there are any serial input
delay(5); // Delay for terminal to finish transmitted
// 5mS work great for 9600 baud (increase this number for slower baud)
serAva = Serial.available(); // Read number of input bytes
for (i=0; i<serAva; i++) // Load input bytes into array
inputBytes[i] = Serial.read();
inputBytes[i] = '\0'; // Put NULL character at the end
return atoi(inputBytesPtr); // Call atoi function and return result
return -1; // Return -1 if there is no input
while (Serial.available()) {
delay(10);
if (Serial.available() >0) {
number = serReadInt();
if (number > -1) {
Serial.print(number);
if(number <= 255) {
value = number;
bla = "Left Blue";
analogWrite(LBlue,value);
else if((number <= 511) && (number >= 256)) {
value = number - 256;
bla = "Left Green";
analogWrite(LGreen, value);
else if((number <= 767) && (number >= 512)) {
value = number - 512;
bla = "Left Red";
analogWrite(LRed,value);
else if((number <= 1023) && (number >=768)) {
value = number - 768;
bla = "Right Red";
analogWrite(RRed, value);
else if((number <= 1279) && (number >= 1024)) {
value = number - 1024;
bla = "Right Green";
analogWrite(RGreen,value);
else if((number <= 1535) && (number >= 1280)) {
value = number - 1280;
bla = "Right Blue";
analogWrite(RBlue, value);
else if (number < 0) {
analogWrite(LBlue,255);
Serial.print(" ");
Serial.print(value);
Serial.println(" - " + bla);
Serial.println("LBlue=0-255 LGreen=256-511 LRed=512-767 RRed=768-1023 RGreen=1024-1279 RBlue=1280-1535");
number = -1;
Processing code for the dimmer:
import oscP5.*; // Load OSC P5 library
import netP5.*; // Load net P5 library
import processing.serial.*; // Load serial library
Serial arduinoPort; // Set arduinoPort as serial connection
OscP5 oscP5; // Set oscP5 as OSC connection
float val = 0;
int message = 0;
// Array allows us to add more toggle buttons in TouchOSC
size(130,130); // Processing screen size
noStroke(); // We don’t want an outline or Stroke on our graphics
oscP5 = new OscP5(this,8000); // Start oscP5, listening for incoming messages at port 8000
arduinoPort = new Serial(this, Serial.list()[0], 9600); // Set arduino to 9600 baud
void oscEvent(OscMessage theOscMessage) { // This runs whenever there is a new OSC message
String addr = theOscMessage.addrPattern(); // Creates a string out of the OSC message
if(addr.equals("/1/fader1")) {
float val = theOscMessage.get(0).floatValue();
int message = (int) val;
else if(addr.equals("/1/fader2")) {
else if(addr.equals("/1/fader3")) {
else if(addr.equals("/1/fader4")) {
else if(addr.equals("/1/fader5")) {
else if(addr.equals("/1/fader6")) {
void draw() {
background(50);
arduinoPort.write(message);
Arduino code for on/off (this works fine, just giving it as an example):
int LBlue = 3;
int LBb = 0;
int LGreen = 5;
int LGb = 0;
int LRed = 6;
int LRb = 0;
int RBlue = 11;
int RBb = 0;
int RGreen = 10;
int RGb = 0;
int RRed = 9;
int RRb;
int message = 0;
if(Serial.available() > 0) {
message = Serial.read();
if (message == 'B') {
LBb = 255;
if (message == 'b') {
LBb = 0;
if (message == 'G') {
LGb = 255;
if (message == 'g') {
LGb = 0;
if (message == 'R') {
LRb = 255;
if (message == 'r') {
LRb = 0;
if (message == 'V') {
RBb = 255;
if (message == 'v') {
RBb = 0;
if (message == 'F') {
RGb = 255;
if (message == 'f') {
RGb = 0;
if (message == 'E') {
RRb = 255;
if (message == 'e') {
RRb = 0;
analogWrite(LBlue,LBb);
analogWrite(LGreen,LGb);
analogWrite(LRed,LRb);
analogWrite(RBlue,RBb);
analogWrite(RGreen,RGb);
analogWrite(RRed,RRb);
Processing code for on/off:
import oscP5.*;
import netP5.*;
Serial arduinoPort;
OscP5 oscP5;
float LBlue = 0.0f;
float LGreen = 0.0f;
float LRed = 0.0f;
float RBlue = 0.0f;
float RGreen = 0.0f;
float RRed = 0.0f;
size(100,100);
arduinoPort = new Serial(this,Serial.list()[0],9600);
if(addr.equals("/1/toggle1")) {LBlue = val; }
else if(addr.equals("/1/toggle2")) {LGreen = val; }
else if(addr.equals("/1/toggle3")) {LRed = val; }
else if(addr.equals("/1/toggle4")) {RBlue = val; }
else if(addr.equals("/1/toggle5")) {RGreen = val; }
else if(addr.equals("/1/toggle6")) {RRed = val; }
void draw() {
background(50);
if(LBlue == 1.0f)
arduinoPort.write("B");
arduinoPort.write("b");
if(LGreen == 1.0f)
arduinoPort.write("G");
arduinoPort.write("g");
if(LRed == 1.0f)
arduinoPort.write("R");
arduinoPort.write("r");
if(RBlue == 1.0f)
arduinoPort.write("V");
arduinoPort.write("v");
if(RGreen == 1.0f)
arduinoPort.write("F");
arduinoPort.write("f");
if(RRed == 1.0f)
arduinoPort.write("E");
arduinoPort.write("e");
print(LBlue);
print(" ");
print(LGreen);
print(" ");
print(LRed);
print(" ");
print(RBlue);
print(" ");
print(RRed);
print(" ");
println(RGreen);
LED sliders.touchosc (428 Bytes)
LED toggles.touchosc (361 Bytes)
