Hi, I'm hoping I posted this in the right place.
I'm a college student and this is my first year dealing with micro controllers and electronics.
My project is this: I want to draw on a touch screen, have the drawing show on the touch screen, and also display on a LED panel.
(Alternatively, click on a button on the touch screen, and have a pattern run on the LED panel. I'm not fussy. I just want to have an input from the touch screen do something on the LED panel.)
I have:
1x Arduino Mega 2560 (https://www.arduino.cc/en/uploads/Main/ ... ematic.pdf)
1x Adafruit 2.8" TFT Touch Shield for Adruino with Resistive Touch Screen (https://learn.adafruit.com/adafruit-2-8 ... -shield-v2)
1x Adafruit 32x32 RGB LED matrix panel (Overview | 32x16 and 32x32 RGB LED Matrix | Adafruit Learning System)
I have downloaded the correct libraries for each device.
I have tested each device and they all work normally. They just don't work together because I haven't got the code right.
Here is the code I'm using:
#include <Adafruit_GFX.h> // Core graphics library
#include <SPI.h>
#include <Wire.h> // this is needed even tho we aren't using it
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
#include <RGBmatrixPanel.h> //for the RGB panel
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
// The STMPE610 uses hardware SPI on the shield, and #8
#define STMPE_CS 8
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
// The display also uses hardware SPI, plus #9 & #10
#define TFT_CS 10
#define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// Size of the color selection boxes and the paintbrush size
#define BOXSIZE 40
#define PENRADIUS 3
int oldcolor, currentcolor;
//For the RGB panel
#define CLK 11 // USE THIS ON ARDUINO MEGA
#define OE 46
#define LAT 45
#define A A10
#define B A11
#define C A12
#define D A13
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false);
void setup(void) {
int x, y, hue;
float dx, dy, d;
uint8_t sat, val;
uint16_t c;
matrix.begin();
Serial.println(F("Touch Paint!"));
tft.begin();
if (!ts.begin()) {
Serial.println("Couldn't start touchscreen controller");
while (1);
Serial.println("Touchscreen started");
tft.fillScreen(ILI9341_BLACK);
// make the color selection boxes
tft.fillRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_RED);
tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_YELLOW);
tft.fillRect(BOXSIZE2, 0, BOXSIZE, BOXSIZE, ILI9341_GREEN);
tft.fillRect(BOXSIZE3, 0, BOXSIZE, BOXSIZE, ILI9341_CYAN);
tft.fillRect(BOXSIZE4, 0, BOXSIZE, BOXSIZE, ILI9341_BLUE);
tft.fillRect(BOXSIZE5, 0, BOXSIZE, BOXSIZE, ILI9341_MAGENTA);
// select the current color 'red'
tft.drawRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
currentcolor = ILI9341_RED;
// See if there's any touch data for us
if (ts.bufferEmpty()) {
return;
// You can also wait for a touch
if (! ts.touched()) {
return;
// Retrieve a point
TS_Point p = ts.getPoint();
Serial.print("X = "); Serial.print(p.x);
Serial.print("\tY = "); Serial.print(p.y);
Serial.print("\tPressure = "); Serial.println(p.z);
// Scale from ~0->4000 to tft.width using the calibration #'s
p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
Serial.print("("); Serial.print(p.x);
Serial.print(", "); Serial.print(p.y);
Serial.println(")");
if (p.y < BOXSIZE) {
oldcolor = currentcolor;
if (p.x < BOXSIZE) {
} else if (p.x < BOXSIZE2) {
currentcolor = ILI9341_YELLOW;
tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
} else if (p.x < BOXSIZE3) {
currentcolor = ILI9341_GREEN;
tft.drawRect(BOXSIZE2, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
} else if (p.x < BOXSIZE4) {
currentcolor = ILI9341_CYAN;
tft.drawRect(BOXSIZE3, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
} else if (p.x < BOXSIZE5) {
currentcolor = ILI9341_BLUE;
tft.drawRect(BOXSIZE4, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
} else if (p.x < BOXSIZE6) {
currentcolor = ILI9341_MAGENTA;
tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
if (oldcolor != currentcolor) {
if (oldcolor == ILI9341_RED)
if (oldcolor == ILI9341_YELLOW)
if (oldcolor == ILI9341_GREEN)
if (oldcolor == ILI9341_CYAN)
if (oldcolor == ILI9341_BLUE)
if (oldcolor == ILI9341_MAGENTA)
if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
I need someone to help me figure out how to make this work. I don't want you to do the project for me. Just point me in the right direction. Thanks!
