Touch screen LCD button problems
I am trying to write a program for a touchscreen LCD and I wanted to have buttons similar to the UTouch button program layout and I have gotten the calibration and button setup the way I want but something is wrong with my code and I can’t get the buttons to react the way that I want. The first button is supposed to say “Sensor 1 On” and when clicked “Sensor 1 Off” and button two would say “Sensor 2 On” and when clicked “Sensor 2 Off” but If sensor one button is pressed it’s supposed to stay clicked down and change color and name until clicked again to turn it off. But when I click sensor one the other button changes color and name as well and if I click that button it changes the buttons back to the original display. I just want for only the buttons clicked to change color and name not all. Please if anyone can help I will be grateful. Oh and I am new to coding so forgive the sloppiness.
#include <UTFT.h>
#include <UTouch.h>
#include <UTFT_Buttons.h>
extern uint8_t nadianne[];
extern uint8_t franklingothic_normal[];
extern uint8_t various_symbols[];
UTFT          myGLCD(ITDB32S,38,39,40,41);
UTouch        myTouch(6,5,4,3,2);
UTFT_Buttons  myButtons(&myGLCD, &myTouch);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myGLCD.setFont(nadianne);
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  myButtons.setTextFont(franklingothic_normal);
  int but1, but2, but3, but4, but5, but6, pressed_button,pressed_button2;
  boolean default_colors = true;
  but1 = myButtons.addButton( 10,  20, 300,  20,"Sensor 1 On" );
  but2 = myButtons.addButton( 10,  60, 300,  20, "Sensor 2 On");
   myButtons.drawButtons();
  while(true)
      if (myTouch.dataAvailable() == true)
      pressed_button = myButtons.checkButtons();
      if (pressed_button==but1)
        if (myButtons.buttonEnabled(but1))
          myButtons.enableButton(but1, true);
          myButtons.setButtonColors(VGA_WHITE, VGA_WHITE, VGA_WHITE, VGA_WHITE, VGA_BLUE);
          myButtons.relabelButton(but1, "Sensor 1 On");
          default_colors=true;
          myButtons.setButtonColors(VGA_BLACK, VGA_WHITE, VGA_WHITE, VGA_WHITE, VGA_RED);
          myButtons.relabelButton(but1, "Sensor 1 Off");
     if (pressed_button==but2)
        if (myButtons.buttonEnabled(but2))
          myButtons.enableButton(but2, true);
        if (default_colors)
          myButtons.relabelButton(but2, "Sensor 2 On");
          default_colors=false;
          myButtons.relabelButton(but2, "Sensor 2 Off");
Do your button drawing in setup(), not loop(). Get rid of the stupid endless loop in the endless loop().
Is there some reason to have to separate blocks with exactly the same conditional? No, there isn't.
If the button is enabled, enable it. Am I missing something?
You need to use Tools + Auto Format to fix your horrid indenting. You have some code inside blocks, where the nesting is wrong.
I am new to coding and have never done this before thanks for the help, I am just starting to learn this stuff and don't mean to make so many mistakes that is why I came to this forum to get help and learn from my mistakes.
If anyone else could help I will appreciate the advice. I am having the same problem, the button when clicked stays at the sensor 1 off and the other button just flickers. All I want is for the buttons to turn on and off the sensors when clicked.
Are you going to ignore it, like you did mine?
no I did what you said and made some other corrections to the code that I didn't realize were there and now it works . Thanks again and plus I didn't even know there was an auto format. Now I need to figure out how to send the commands via bluetooth from this arduino to another to perform the actions.
