I am using a serial touchscreen with an arduino mega and am having some problems reading touch coordinates from the screen. The screen works fine with serial commands sent from the computer, but when the commands come from arduino, about 50% of the bytes are 0xFF (-1, aka no data) or incorrect.
The screen sends 2 integers (x coordinate, y coordinate) over serial with the most significant bytes first. The first bytes tend to mess up more often. When the touch coordinates are small, it works better. Here is the relevant part of code:
void getTouch(int *x0_touch, int *y0_touch){
Serial1.flush();
Serial1.write(0x6F); //Tell screen to send touch coordinates
Serial1.write(0x01); //Tell screen to send touch coordinates
while(Serial1.available() < 1) {}
delay(30);
char a = Serial1.read(); //x coordinate, high byte
char b = Serial1.read(); //x coordinate, low byte
char c = Serial1.read(); //y coordinate, high byte
char d = Serial1.read(); //y coordinate, low byte
*x0_touch = a; //Put bytes back into integer form-- this part works because if I put my own values
*x0_touch = (*x0_touch << 8) | b; // in instead of reading them, it comes out right
*y0_touch = c;
*y0_touch = (*y0_touch << 8) | d;
I've messed around with Serial1.available() but with no luck. Delays between Serial1.read()'s didn't work either.
Any suggestions?
