Touch screen to Processing
Hi, im trying to create a program so that I can draw an a Nintendo DS touch screen, and a program on processing will draw where it is on the touch screen.
Arduino Code:
int y1 = A0;
int x2 = A1;
int y2 = A2;
int x1 = A3;
int readX(){
  pinMode(y1, INPUT);
  pinMode(x2, OUTPUT);
  pinMode(y2, INPUT);
  pinMode(x1, OUTPUT);
  digitalWrite(x2, LOW);
  digitalWrite(x1, HIGH);
  delay(5); //pause to allow lines to power up
  return analogRead(y1);
int readY(){
  pinMode(y1, OUTPUT);
  pinMode(x2, INPUT);
  pinMode(y2, OUTPUT);
  pinMode(x1, INPUT);
  digitalWrite(y1, LOW);
  digitalWrite(y2, HIGH);
  return analogRead(x2);
  int x = readX();
  int y = readY();
  Serial.print(x);
  Serial.print(',');
  Serial.print(y);
  Serial.println(' ');
  delay(0); //just to slow this down so it is earier to read in the terminal - Remove if wanted
Processing Code:
import processing.serial.*;
Serial myPort;
  size( 800, 600 );
  background( 0 );
  myPort = new Serial(this, Serial.list()[2], 9600);
  myPort.bufferUntil(' ');
void draw() {
void serialEvent( Serial myPort )
  String inString = myPort.readStringUntil( '\n' );
  if( inString != null )
    inString = trim( inString );
    int[] coords = int( split( inString, ',' ) );
    background(0);
    stroke(255);
    fill(255);
    int x = coords[0];
    int y = coords[1];
  ellipse(x, y, 10, 10);
It somtimes says "NullPointerException" and WARNING: RXTX Version mismatch
How can I fix this?
The RXTX library mismatch can generally be ignored.
The NullPointerException is most likely happening because you are referencing the 3rd element in a list without three elements.
Do you KNOW that there are three serial ports available, and that the Arduino is connected to the thord one?
Add
println(Serial.list());
just before the myPost declaration, to verify that there are at least three COM ports listed.
Yes, the Arduino is connected to the third one.
Somtimes I also get the error "disabling serialEvent() for //./COM3"
