I am having a problem with my code. I have a script that is suppose to display the on/off times of two valves. This shows up all ok. The touch screen has two buttons > and +.
When selecting the > button the screen highlights the next time either hour or min’s for one of the valves. Then when selecting the + button I can adjust the time up.
This all works great for the first valve for on and off times. but on valve 2 when I get to the off min time it does not update.
The screen some times stays on 1.
I have added extra valves up to 4 in total all all update for On Hr & min and off Hr but not off min.
I cant work out what is going wrong.
Currently this is running on the mega with 3.2" TFT screen
Below is a cut down portion of my script. which does not work on V2 Min Off update.
Any help please
#include <UTFT.h>
#include <ITDB02_Touch.h>
#include <UTFT_Buttons_ITDB.h>
UTFT myGLCD(SSD1289,38,39,40,41);
ITDB02_Touch myTouch(6,5,4,3,2);
UTFT_Buttons myButtons(&myGLCD, &myTouch);
extern uint8_t SmallFont[];
int bplus, bneg, forward, back, pressButton; // button variables
int var[8]; // hold time settings
int a; // used to change digits selected in settings page
char* leadingZero[]={"00","01","02","03","04","05","06","07","08","09"}; // used to display number below 0 correct
#define green 0x07E0
#define white 0xFFFF
Serial.begin (9600);
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch(1);
myTouch.setPrecision(PREC_MEDIUM);
myGLCD.setBackColor(0, 0, 0);
boolean default_color = true;
myButtons.setTextFont(SmallFont);
myGLCD.setColor(white); // set white
myGLCD.setFont(SmallFont);
bplus = myButtons.addButton( 165, 160, 65, 30, "+"); // add up button
forward = myButtons.addButton( 85, 160, 65, 30, ">"); // move to next digit button
a = 1; // set a to start at 1
settingsPage (); // initial setup page
Serial.println (a);
Serial.println (var[a]);
settingUpdate (); // update page with current selected time and add up when + button operated
if (myTouch.dataAvailable() == true){
pressButton = myButtons.checkButtons();
// if > button operated then add on one to variable a which will later highlight the next digits to be updated.
if (pressButton == forward){
a = a +1;
if (a == 10){
a = 1;
// if + button operated add 1 to var[a]
if (pressButton == bplus)
var[a] = var[a] +1;
void settingUpdate () {
// This code writes the times on the page for on and off for each valve
// V1 ON times
// var[1] Hour
// var[2] Minute
if (a == 1)
myGLCD.setColor(green);
if (var[1] < 10)
myGLCD.print (leadingZero[var[1]], 100, 40);
myGLCD.printNumI (var[1], 100, 40);
if (a == 2)
if (var[2] < 10)
myGLCD.print (leadingZero[var[2]], 123, 40);
myGLCD.printNumI (var[2], 123, 40);
// V1 OFF times
// var[3] Hour
// var[4] Minute
if (a == 3)
if (var[3] < 10)
myGLCD.print (leadingZero[var[3]], 255, 40);
myGLCD.printNumI (var[3], 255, 40);
if (a == 4)
if (var[4] < 10)
myGLCD.print (leadingZero[var[4]], 280, 40);
myGLCD.printNumI (var[4], 280, 40);
// V2 ON times
// var[5] Hour
// var[6] Minute
if (a == 5)
if (var[5] < 10)
myGLCD.print (leadingZero[var[5]], 100, 60);
myGLCD.printNumI (var[5], 100, 60);
if (a == 6)
if (var[6] < 10)
myGLCD.print (leadingZero[var[6]], 123, 60);
myGLCD.printNumI (var[6], 123, 60);
// V2 OFF times
// var[7] Hour
// var[8] Minute
if (a == 7)
if (var[7] < 10)
myGLCD.print (leadingZero[var[7]], 255, 60);
myGLCD.printNumI (var[7], 255, 60);
if (a == 8)
if (var[8] < 60)
myGLCD.print (leadingZero[var[8]], 280, 60);
myGLCD.printNumI (var[8], 280, 60);
void settingsPage (){
myGLCD.print ("V1 ON Time ", 10, 40);
myGLCD.print (":", 115, 40);
myGLCD.print ("V1 OFF Time", 160, 40);
myGLCD.print (":", 272, 40);
myGLCD.print ("V2 ON Time ", 10, 60);
myGLCD.print (":", 115, 60);
myGLCD.print ("V2 OFF Time", 160, 60);
myGLCD.print (":", 272, 60);
myButtons.drawButton(bplus);
myButtons.drawButton(forward);
Also when uploaded and I operate the > arrow the V2 OFF Min time displays lines. wired
