hello;
I have successfully connected the touch sensor to the arduino but I would like to put a screen that displays the number of times I touch the touch sensor.
can someone please help me ?
hello;
Have you tried the example programs from the LCD library ?
Nope; I'm going to try
Don't try to write the program all in one go. Start small and write portions and test them You say
You have connected it, but can you read it and display its state on the Serial monitor ?
Can you detect when its state changes ?
What counts as a change of state anyway ?
Maybe take a look at the StateChangeDetection example in the IDE
I have programmed the touch sensor alone and yes; the serial monitor indicates whether or not I touch the touch sensor. However, I have no Idea for the program of my LCD. I want the program to indicate the number of times I find the sensor.
Try the LCD library examples first
Start by adding 1 to a counter when the reading from the sensor changes from not to touched to touched. Did you look at the example to detecting a change of state as I suggested ?
Please post your code that shows the sensor state in the Serial monitor
Ok; thanks I zill see
int ledPin = 13;
pinMode(ledPin, OUTPUT);
pinMode(ctsPin, INPUT);
int ctsValue = digitalRead(ctsPin);
if (ctsValue == HIGH){
digitalWrite(ledPin, HIGH);
Serial.println("TOUCHED");
else{
digitalWrite(ledPin,LOW);
Serial.println("not touched");
If you look at the example I suggested you should be able to see how to detect when the sensor state changes from LOW to HIGH. When that occurs add 1 to a counter and print it
