Touch sensor not working properly
I have made a water dispenser with three different modes for filling a glass, 2 different bottles.
The order is...
bottle
school bottle
glass
The sensor works fine when i press it the first time to change the mode to "bottle". But then it triggers twice and skips to "glass" instead of "School Bottle". Pls help me with this.
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
LiquidCrystal_I2C lcd(0x27,16,2);
//pins:
const int HX711_dout = 4; //mcu > HX711 dout pin
const int HX711_sck = 5; //mcu > HX711 sck pin
int mode;
int x=2,y=0;
int touch;
float i;
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
  lcd.init();
   lcd.backlight();
  Serial.begin(57600); delay(10);
  Serial.println("Starting...");
  lcd.print("Starting");
pinMode(7,INPUT);
 pinMode(8,OUTPUT);
 pinMode(9,OUTPUT);
  pinMode(13,OUTPUT);
 pinMode(12,OUTPUT);
 digitalWrite(8,LOW);
  LoadCell.begin();
  LoadCell.setReverseOutput(); //uncomment to turn a negative output value to positive
  float calibrationValue; // calibration value (see example file "Calibration.ino")
  calibrationValue = EEPROM.read(0); // uncomment this if you want to set the calibration value in the sketch
  //EEPROM.begin(512); // uncomment this if you use ESP8266/ESP32 and want to fetch the calibration value from eeprom
#endif
  //EEPROM.get(calVal_eepromAdress, calibrationValue); // uncomment this if you want to fetch the calibration value from eeprom
  unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
  boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
  LoadCell.start(stabilizingtime, _tare);
  if (LoadCell.getTareTimeoutFlag()) {
    Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
    while (1);
  else {
    LoadCell.setCalFactor(calibrationValue);
    Serial.println("Startup is complete");
  static boolean newDataReady = 0;
  const int serialPrintInterval = 0; //increase value to slow down serial print activity
  // check for new data/start next conversion:
  if (LoadCell.update()) newDataReady = true;
  // get smoothed value from the dataset:
  if (newDataReady) {
    if (millis() > t + serialPrintInterval) {
       i = LoadCell.getData();
      Serial.print("Load_cell output val: ");
      Serial.println(i);
      lcd.setCursor(0,1);
      lcd.print(i);
      newDataReady = 0;
      t = millis();
  // receive command from serial terminal, send 't' to initiate tare operation:
  if (Serial.available() > 0) {
    char inByte = Serial.read();
    if (inByte == 't') LoadCell.tareNoDelay();
  // check if last tare operation is complete:
  if (LoadCell.getTareStatus() == true) {
    Serial.println("Tare complete");
   touch=digitalRead(7);
   Serial.println(touch);
 if (touch==HIGH&&x==1){
  Serial.println("glass");
  lcd.clear();
        lcd.setCursor(0,0);
lcd.print("Glass");
 lcd.setCursor(0,1);
lcd.print(i);
   x=2;
   y=1;
 else if (touch==HIGH&&x==2){
  Serial.println("bottle");
    lcd.clear();
        lcd.setCursor(0,0);
lcd.print("Bottle");
 lcd.setCursor(0,1);
lcd.print(i);
    x=3;
    y=2;
else if (touch==HIGH&&x==3){
  Serial.println("School Bottle");
    lcd.clear();
        lcd.setCursor(0,0);
lcd.print("School Bottle");
 lcd.setCursor(0,1);
lcd.print(i);
    x=1;
    y=0;
if (x==3){
  if (i>436&&i<2476){
    digitalWrite(8,HIGH);
    else {
  if (x==2){
  if (i>237&i<906){
    else {
  if (x==1){
  if (i>383&i<2580){
    else {
   if (y==1){
    y=0;
    motordown();
    delay(600);
    motorstop();
    if (y==2){
    y=0;
    motorup();
    delay(600);
    motorstop();
void motorup(){
  digitalWrite(12,HIGH);
  digitalWrite(13,LOW);
void motordown(){
  digitalWrite(13,HIGH);
  digitalWrite(12,LOW);
  void motorstop(){
Please give the variables meaningful names like "menuChoice" instead of "x" and "y" and "i" and "t", perform auto format using ctrl-T, and repost.
#include <EEPROM.h>
#endif
LiquidCrystal_I2C lcd(0x27, 16, 2);
//pins:
int mode;
int menuchoice = 2, lowerpipe = 0;
int touch;
float weight;
  lcd.init();
  lcd.backlight();
  pinMode(7, INPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  digitalWrite(8, LOW);
  LoadCell.begin();
#endif
    while (1);
  else {
  if (newDataReady) {
      weight = LoadCell.getData();
      Serial.println(weight);
      lcd.setCursor(0, 1);
      lcd.print(weight);
      newDataReady = 0;
      t = millis();
  touch = digitalRead(7);
  if (touch == HIGH && menuchoice == 1) {
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("Glass");
    lcd.print(weight);
    menuchoice = 2;
    lowerpipe = 1;
  else if (touch == HIGH && menuchoice == 2) {
    lcd.clear();
    lcd.print(weight);
    menuchoice = 3;
    lowerpipe = 2;
  else if (touch == HIGH && menuchoice == 3) {
    lcd.clear();
    lcd.print(weight);
    menuchoice = 1;
    lowerpipe = 0;
  if (menuchoice == 3) {
    if (weight > 436 && weight < 2476) {
      digitalWrite(8, HIGH);
    else {
  if (menuchoice == 2) {
    if (weight > 237 & weight < 906) {
    else {
  if (menuchoice == 1) {
    if (weight > 383 & weight < 2580) {
    else {
  if (lowerpipe == 1) {
    lowerpipe = 0;
    motordown();
    delay(600);
    motorstop();
  if (lowerpipe == 2) {
    lowerpipe = 0;
    motorup();
    delay(600);
    motorstop();
void motorup() {
  digitalWrite(12, HIGH);
  digitalWrite(13, LOW);
void motordown() {
  digitalWrite(13, HIGH);
  digitalWrite(12, LOW);
void motorstop() {
Thanks for the clean up, it's very helpful. It's very likely that the problem you mention is because you have no state change detection on the sensor input. In other words, detecting when it becomes HIGH, not when it only is HIGH. You can do that by storing its value and seeing if the current value has changed.
Did you mean
  static boolean newDataReady = false;
Boolean variables really don't have integer values. It's only an implementation detail that false happens to be 0.
Why did you declare it as a static local variable instead of a global? Is this your own code?
i have merged my own code with the example code of the hx711 sensor library. It is a weight sensor.
Any progress from your research on State Change Detection?
Also you need to re-examine your entire code base to ensure it complies with proper C usage. Here you have used bitwise 'and' instead of boolean 'and':
There may be more... try:
    if (weight > 383 and weight < 2580) {
Why do you name only two pins out of about 8 that you use?
//pins:
  pinMode(7, INPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
this part is working fine...i am having problem in the switching mode part.
One of the problems I showed you is a critical error. It can't work that way. So unless you fix that, I'm not willing to help you any further. If you're really confident that you know where the problem is, you can fix it.
If you have made any changes to your code, please post it again.
Also, any progress from your research on State Change Detection?
