i cant get my Waveshare 4" Touch running. The first step is done, i get strange stuff at the serial monitor.
I can run the Display with the Sample gallerie, when i try to run the display with the UTFT Lib the Display doesnt show anything but the serial monitor is showing these strange signs:
Please post the full sketch that causes the strange Serial Monitor output.
If possible, you should always post code directly in the forum thread as text using code tags:
Do an Auto Format (Tools > Auto Format in the Arduino IDE or Ctrl + B in the Arduino Web Editor) on your code. This will make it easier for you to spot bugs and make it easier for us to read.
In the Arduino IDE or Arduino Web Editor, click on the window that contains your sketch code.
Press "Ctrl + A". This will select all the text.
Press "Ctrl + C". This will copy the selected text to the clipboard.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
Press "Ctrl + V". This will paste the sketch between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
Repeat the above process if your sketch has multiple tabs.
This will make it easy for anyone to look at it, which will increase the likelihood of you getting help.
If the sketch is longer than the 9000 characters maximum allowed by the forum, then it's OK to add it as an attachment. After clicking the "Reply" button, you will see an "Attachments and other settings" link.
When your code requires a library that's not included with the Arduino IDE please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
My apologies. I would look at the schematic and program accordingly.
e.g. set RST, DC, CS as required. spi(hi). spi(lo)
You have to send two spi() bytes for every lcd_command or lcd_data() even if it is an 8-bit argument.
The net result is going to be much like the SPI_5_wire interface. Except that 8-bit commands and 8-bit arguments always use spi(hi), spi(lo)
I don't have this type of display. I do not intend to buy one.
I would imagine that someone, somewhere has bought this display and has implemented the hardware driver for UTFT.
No. You would not attempt to connect 0, 1 or use a Uno 8-bit parallel driver. (that is what created garbage)
You would use 5-wires + RESET.
I take this to mean that there is a sketch named "Sample gallerie" that works fine, and another sketch that uses the UTFT lib which causes the display to not show anything and bad output to Serial Monitor.
Then you said:
Sample galerie is attached
It sure sounds to me like the "stuff" you attached is the sketch that works, not the sketch that doesn't work.
