elac:
Scroll down to the description, it states this - "Type: without touch panel"
Now on the link I posted the description states -"Type: touch panel"
Thank you elac. Typical case of stock photos as typical with the chinese XD
arduino123456789:
many thanks for this link!
know any how to connect it?
or is it the same as the display i have, that uses ili9341 too?
thanks
For the screen is the same as the 2.2. I don't know about the touchscreen tough
Site says -"5V compatible, use with 3.3V or 5V logic"
Don't see why they would purposely lie.
The link to the TFT screen and driver info is on the product page it is labeled "Download" in a purple blue color.
Though there is nothing related directly to the completed module in there.
Only one extra pin on the Arduino board, 5 pins on the module.
Casemod, do you not have to connect the remaining SPI pins on this module? Just connect the CS pin and let the rest float?
I was under the impression that all SPI device pins must connect to the Arduino board with each device having it's own CS pin.
elac:
It was mentioned that the touch "consumes" 5 pins.
I clarified it only "consumes" only one additional pin as the interface itself is the same .
I don't recall having seen or debated anything about how it should be wired, right?
elac:
My fault, I didn't use "consume" with enough detail, I was referring to the touch screen consuming 5 pins on the module board it and the screen are attached to. Apposed to the module without a touch screen which the pictures show the touch screen pins on the module but they are not used/consumed because of no touch screen present.
No, not discussed it's wiring I was just asking you for my own clarification as I do not own this particular TFT screen module and you do.
As for my questions, what I'm getting at is this:
Is the SPI for the screen and touch function internally connected in the module except for the CS pins?
Or do the SPI pins have to externally share the Arduino board SPI pins except for individual CS pins? Like the SD card slot.
But how to connect the touch panel to work with the adafruit ili9341 touch paint example?
I have no idea. UTFT has support for that controller with the Utouch library. it is the same found on the SSD1289 based displays such as the ITDB24E.
elac:
Makes sense now.
elac:
That's all.
There's nothing wrong on what you said, other than you didn't mention any wiring on the post I first quoted.
They don't have any internal connection. I usually short them on the panel itself and just attach the CS to whatever feature I want to use or not to use.
Some guys use bit-bang SPI for the touch. I am yet to understand the point as it will cause extra overhead to the CPU, but regardless if you use that method you will need the extra pins wired separately.
Remember the CPU perform actions sequentially so even in the best case, if you were using another (hardware) SPI port the speed would still be the same (Actually slower on soft SPI). There is an exception, on CPU's with DMA capabilities, but this is only supported on the DUE and even then the Arduino environment doesn't make use of such feature.
