Hello,
I have an Arduino Uno with a 2.4" TFT touchscreen, but I was wondering if I can still use the I2C protocol to communicate with another Arduino. More info on the screen: http://www.smokeandwires.co.nz/blog/a-2-4-tft-touchscreen-shield-for-arduino/
Kind regards, Jeffrey
If it does not use the I2C pins you should be able to do so. Your post was not overly informative and you did not post a clickable link which makes it a pita following it from a mobile device.
The link contains a pin layout. It says A4 is used as LCD reset. A5 is unused.
