Touchsensor sleep toggle
Hi guys,
I need some help with the coding of my system. My prototype has a led(pin 13) and a catalex digital capacitive touch sensor signal to pin 3. I want to make a toggle system when I press the button the first time the arduino is going to sleep when I pressed it again it will wake and start to blink the LED.
As always, post your sketch.
// hardware interrupt stuff
#include <avr/sleep.h>
#define INT0 0
#define INT0_PIN 2
#define INT1 1
#define INT1_PIN 3
// touch sensor pin
#define TOUCH_PIN 2
// led pin
#define BLINK_PIN 13
// global flags
int buttonPushed;
void wakeUp(){
 // blink
 digitalWrite(BLINK_PIN, HIGH);
 //delay(1000);
 //digitalWrite(BLINK_PIN, LOW);
 delay(300);
void prepareToSleep(){
 //prepare actions for sleep
 digitalWrite(13, LOW);
void wake(){
 // reset button state
 buttonPushed=0;
void toggle(){
 detachInterrupt(1);    // this seems to be allowed in callback
 if(digitalRead(TOUCH_PIN) == HIGH)
   Serial.println("Touch");
   if(buttonPushed == 0)
     buttonPushed = 1;
     buttonPushed = 0;
void sleep(){
 wakeUp();  //application specific
 set_sleep_mode(SLEEP_MODE_PWR_DOWN);
 attachInterrupt(INT1,wake,CHANGE); // rebind interrupt
 sleep_mode(); // sleeping
 // On Off Toggle setup
 pinMode(INT1_PIN, INPUT);  // set switch pin to input
                            // to limit current
 attachInterrupt(INT1,toggle,CHANGE);
 buttonPushed=0; // set to 1 = sleep after reset
                 //        0 = run loop after reset
 // app specific setup here
 pinMode(BLINK_PIN, OUTPUT);
 // debug message
 Serial.println(buttonPushed);
 if (buttonPushed == 1) {
   sleep();
   // reset button events to sleep
 // do important things
 wakeUp();
