Touchshield Slide Text
Is it possible to make the numbers on the slide bigger????
example
text(test1,60,100);
test1 is being floated (4.9158), the results display fine on the screen, i just wanted to make them bigger.
Cheers
You are going to have to supply more data.
What touchshield, link? There are a few.
Slide? What is that.
ok
i'm refering to the Touchshield Slide.
i am getting the touchshield Slide (Slide) to display sensor data from the arduino using hardwaresensor.h, all this works fine.
The end result is just monitoring a analog input on the arduino which talks to the touchshield slide which then in turn displays the results in a 'float' ie 4.765
float pinFloat = (test1*15.53/1023.0) //test1 is the data coming from arduino.
text(pinFloat,20,20);
The default size the touchshield slide displays numbers is too small, just wanted to know if i could display the results in a larger 'font' .
hope this makes sense
Cheers
It does but why no links like requested?
Spent some time googling it but still couldn't find a link to the library.
Look in the library file to see if there is a setting / call for the font size. In theory this should be possible but I don't know if the writers have included it. You can always write your own.
Sorry here is a link for the Touchshield Slide
http://www.liquidware.com/shop/show/TSL/TouchShield+Slide
i don't think it will be in the hardwaresensor.h, that just does the serial comms.
i will try to look in all the files related to the touchshield slide.
Thanks for the hep so far.
Found built in function 'dispPutLargeNumString()' , works a treat!
