Hello,
I want to control a HS 110 made by tp-link using an esp controler.
Has anybody experience in programmierung?
This is the configuration:
One esp32
One temperatur sensor.
If the temperature excceds a temperature value it has to switch off the power on the HS110.
How can I make this?
Thanks a lot in advance.
"HS 110" + ESP8266 + ESP32 - Search (bing.com)
of interest:
Reverse Engineering the TP-Link HS110 (softscheck.com)
The Introductory tutorials section is for tutorials that e.g. you write, not for questions. Hence your topic has been moved to a more suitable location on the forum.
@sterretje
Thanks for this hint.
I moved it as required.
Hello,
thanks to your answers.
I found a good solution:
https://github.com/kj831ca/KasaSmartPlug
It works for me.
