TP-Link / Kaza cipher
I am working on a project to write to and read from a TP Link / Kaza power strip or smart plug.
The data that is sent is encrypted json that has been "autokey encrypted".
So far I have been able to convert a typescript encrypt function and it works well. I get the expected result. However, I need to add a "header" to my encrypted data. That data is 3 null bytes followed by a byte that is a measure of the length of the encrypted bytes.
The same typescript has this bit to encrypt with headers, however, I've hit a bit of a wall trying to convert it to something usable. Can someone nudge me along the path ?
First are the two typescript functions: (borrowed from tplink-smarthome-crypto/index.ts at main · plasticrake/tplink-smarthome-crypto · GitHub)
 * Encrypts input where each byte is XOR'd with the previous encrypted byte.
 * @param input - Data to encrypt
 * @param firstKey - Value to XOR first byte of input
 * @returns encrypted buffer
export function encrypt(input: Buffer | string, firstKey = 0xab): Buffer {
  const buf = Buffer.from(input);
  let key = firstKey;
  for (let i = 0; i < buf.length; i += 1) {
    // eslint-disable-next-line no-bitwise
    buf[i] ^= key;
    key = buf[i];
  return buf;
 * Encrypts input that has a 4 byte big-endian length header;
 * each byte is XOR'd with the previous encrypted byte.
 * @returns encrypted buffer with header
export function encryptWithHeader(
  firstKey = 0xab
): Buffer {
  const msgBuf = encrypt(input, firstKey);
  const outBuf = Buffer.alloc(msgBuf.length + 4);
  outBuf.writeUInt32BE(msgBuf.length, 0);
  msgBuf.copy(outBuf, 4);
  return outBuf;
Second is what I have so far. This part works well and produces the expected results
// This part works well and produces the expected results
String encrypt(String input)
    int16_t firstKey = 0xab;
    String buf;
    int key;
    int i;
    buf = input;
    key = firstKey;
    i = 0;
    for (;i < buf.length();(i = i + 1))
        buf[i] ^= key;
        key = buf[i];
    return buf;
// This does not function yet, as I'm pretty lost..
// This was orginally converted from typescript with https://andrei-markeev.github.io/ts2c/
// I started work on converting this, but ran into errors I don't know how to solve.
String encryptWithHeader(String input){
    String msgBuf;
    String outBuf;
    char * null = NULL;
    msgBuf = encrypt(input);
    outBuf = msgBuf.length() +1;
//this is where I got lost...
    assert(null != NULL);
    null[0] = '\0';
    strncat(null, outBuf, msgBuf.length());
    str_int16_t_cat(null, 4);
    outBuf = msgBuf + 4
    return outBuf;
Finally, the data:
//this is the unencrypted json
String offMsg = "{\"system\":{\"set_relay_state\":{\"state\":0}}}";
//current encrypt function produces:
d0f281f88bff9af7d5ef94b6c5a0d48bf99cf091e8b7c4b0d1a5c0e2d8a381f286e793f6d4eedea3dea3
//the working "withheaders" would produce:
00002ad0f281f88bff9af7d5ef94b6c5a0d48bf99cf091e8b7c4b0d1a5c0e2d8a381f286e793f6d4eedea3dea3
Admittedly my C/C++ ability is very limited and I can spell typescript, that's about all. I have a very extensive history with PHP. As useful as that is. So, I understand the basics of data structures and whatnot, but I'm venturing off into areas I've never been in. Any help would be greatly appreciated.
I think you will have trouble with storing binary bytes into a String. I recommend you use byte arrays. If the data length is limited to 255 you can fit any message plus header into a 259-byte array.
my understanding of byte arrays and whatnot is quite limited. can you show me an example that might help me get this code where needs to be?
