I can someone tell me if it is ok to hook up the OUT on these boards in series? I am trying to build a 12v system and I am not sure if this will damage the charging boards.
onesojourner:
Sorry. To clarify I plan to use 3 charging boards with 3 18650s. I will power the boards with 5v.
The board uses common ground (supply and battery), so your plan could work with three separate 5volt (cellphone) supplies. Using one 5volt supply (e.g. connecting them to one USB hub) will short out two batteries.
Maybe better to use a proper 3-cell ballance charger.
Leo..
onesojourner:
Sorry. To clarify I plan to use 3 charging boards with 3 18650s. I will power the boards with 5v. I need to have 12v from the 3 batteries though.
Don't do that. It will destroy your charging boards because of short circuit at the output.
Should be used separately 3-charger as @Wawa recommended.
It will damage your unit. The out port provides only 4.2 -4.3 volts , just enough to charge a single li-ion cell.
So you shouldn't connect your cells in series.
Some people tried connecting cells in parallel but since this one doesn't have a balancing circuit you shouldn't do that either.
Just stick with 1 unit per cell like everyone else suggested.
Can the input to these boards all use the same 5v source provided it there are enough amps?
Can I run all three outputs in parallel and then step up the 4.2v to 12v?
Here is a quick sketch I did a while back. I am trying to build a simple solar powered 18650 powered light. I have a few P channel mosfets laying around. They are not logic level. I believe they need 9v at the gate to shut off.
onesojourner:
I am using 3 boards and 3 batteries.
If you look at the board pictured in the original post, you can see the trace connecting the input "-" to the output "OUT-". If you wire the outputs in series with a common ground at "-" two of the "OUT+" pins will be shorted to ground. The charger may tolerate this, since they current limit by design, but shorting batteries that have any charge on them is not going to end well.
onesojourner:
So are you saying the chip would see the 12.6v?
Yes, and it won't charge. It may even fry that chip. (haven't checked the ratings)
Absolutely. Even if there aren't enough amps it will work by charging at a lower current.
It should work. Although that 4.2v will soon drop back to 3.7v.
maybe you should tell more about your pproject and we can help you find the best solution.
There are better options, You could use a 19 or 18v laptop battery pack. It has a built in balancing circuit. You just have to step down the voltage to 12V.
Or
you could use a DIY powerbank kit like this which could charge multiple 18650 cells without any problems.
I am trying to build 18650 solar light. I would like the lights to come on when it gets dark and go off when the batteries reach a set voltage or when it gets light out.
LED = 12V * 50mA = 0.6W
I have 3 solar panels to choose from:
Solar Panel 2.5W 5V/500mAh (x2)
Solar Panel 12V 3W
I have some p-channel mosfets (9v gate) and I have some logic level P channels on the way.
I have a few cheap 18650s, and I hope to have some Panasonic 3400s fairly soon.
onesojourner:
You can use a small photoresistor to get the lights to turn on when it gets dark and turn off when it's not.
The TP4056 module has a discharge cutoff function that stops the battery from providing power when it's charge is too low to prevent any damage to the battery.
Well, why didn't you say this before. You don't really need 3 batteries for that.
A single 2600mAH 18650 has about 9.3WH so it can power you 0.6W LED for about 13-15 hours = more than enough to power your light from for a dusk to dawn.
Them Panasonic 3400s will give you well above a 20 hour runtime.
You just have to boost your battery voltage to attain 12V
Solar Panel 12V 3W
Just use 1x 5V (2.5W) solar panel for the setup I suggested. 500mA is more than enough to charge a single 18650 cell. At optimum conditions your panel will fully charge a 2600mAH cell within 6 hours.
You don't really need MOSFETs for a 0.6W LED, Transistors will do the job. Just connect that photoresistor to the Transistor.
Noobian:
Maybe I've missed something, but I don't think this is correct. The TP4056 is a charge only device.
Noobian:
Dont beleive you.
The output of the TP4056 module connects direct to the battery and the load is connected across the same connections as well.
As the load does not go through the TP4056 module even if the TP4056 module were to shut down, the battery is still connected to the load.
MrMark:
Actually you did miss something ;), did you not see the DW01A IC and the FS8205A dual MOSFET in OPs picture? The second version of TP4056 modules comes with these protection chips.
Julian Ilett has done a good review on these modules.
srnet:
Dont beleive you.
Wrong, you're talking about these first version of the TP4056 modules, OP has posted the second version with battery protection features. Please read the Original post before replying to any of the later posts.
Noobian:
Fair point, although the original post has now been edited.
However, a cut of voltage of 2.5V is way too low. Not a good idea to let the batteries discharge that low on a regular basis.
srnet:
That depends on the battery. Usual 18650s has a discharge cut-off voltage at 2.75 volts but since the OP said he might use them Panasonic 3400s, which has a discharge cut-off at 2.5v.
Anyways these cheap modules are only providing this feature as a last line of defense for cheap unprotected cells. Good 18650s have their own built-in protection chip anyway.
Regularly discharging cheap cells to 2.5 volts will destroy them like you said but the OPs project will not use that much power to completely drain a 18650, unless he is planning to use an Ultrafire 10,000mAH crap.
Noobian:
My plan was to let the solar panel act as the photoresistor.
So a couple things related to battery capacity. I have some cheapo cells that I would like to use if possible. I am guessing those will be somewhere around 1000mah. With that said I may need significantly more capacity to get through a couple of cloudy winter days.
I have the mosfet in the plan just because that is what I have on hand. I can get something else if it won't do the job though.
