tp4056 charging module current
Hi guys!
I am planning to buy few of these modules, but there is something that i don't really know.
According to the description:
for example: 2PCS 5V Micro USB 1A 18650 Lithium Battery Charging Board Charger Module 806998725778 | eBay
It has a maximum of charging current : 1A, which basically means the maximum current is 1A that can flow from the usb port to the battery cell, if i am right..
It also has some protection for the battery, and battery over-current protection current: 3 A.
Does that mean that i can pull out max 3A from the OUT terminals?
Or what's the maximum current output?
I need at least 2A for the project (peak) - so if this module is not good enough, can you link me one which can output 2A?
Thx in advance :slight_smile:
buliko:
Depends.
Most USB ports can only deliver 500mA.
buliko:
The battery protection circuit is rated for 3A max. 2A should be ok then.
Leo..
