I am using a TP4056 module for charging and protecting a 18650 li ion battery. The supplier states that I need to connect an input on the charging circuit to activate the battery protection circuit.
I provided an input to the charger then removed it; and then the project powered on. However after powering off the project and turning it on after a while the project does not power up anymore. I tried connecting power to the charging circuit then removed it and the project powers up.
How come I need to keep activating the battery protection circuit? I thought I only have to do it once unless I disconnected the battery then connected it.
Hmm, I doubt that as it works after I turn it off and on for a few times; it's when I leave it off for a while then try to turn it on it does not power up.
Thing is I disposed of all the electronics that came with it (the electric shaver, that is what the project is). How should I approach this issue? What I need is a charging and protection circuit; and a way to power the motor from the battery, correct? Cheers
Edit:
I checked on AliExpress and they sell the motherboards for it. A bit pricey though, and delivery delay; I would like to come up with a custom solution. The shaver I'm trying to fix is the Wahl 8591.
