Hello Friends! Newb question here as my pcb board is not waking up my 90-100 mAh 3.7v battery. From what i'm reading I need to switch the resistor to something like 20-30k ohms. My question is 1. Is the existing resistor the reason battery is not waking up. Why when I switch it to 1.2k ohm it does wake it up (don't worry didn't blow myself up)? How will switching it lower wake it up and also making it higher wake it up? DOes this even make sense? Maybe the resistor isn't the problem? Thanks for any advice.
It sounds like you are using a power pack not a battery. Please clarify and post a simple sketch as to hot they are connected.
