TP5100 Charger module
Can this module be connected in parallel, so that the charging current can be above 2 amperes?
I do not know about this specific module. Generally power supplies cannot be connected in parallel and be expected to share current.
If one power supply output happens to have a higher out put voltage than the other, even by a very small amount, then it will provide the majority of the current.
It will only be when the higher voltage output falls under load to the voltage of the lower one, will the lower one supply current.
Why?
Why would you ever want to do that? :roll_eyes:
