Dear friends,
I need to work with two TPA81 sensors, but one of them provides temperature values 5ºC ??higher than the other, somebody can indicate which calibration procedures we must do to calibrate/correct the TPA81?
Best regards,
Paulo Santos
Dear friends,
Best regards,
Paulo Santos
Can you provide us with a link to the datasheet of TPA81? Many sensors describe their calibration routines in their datasheets.
Alternative is to program an offset in the Arduino sketch (just add x degrees)
How did you measure the 5 degrees difference? Did you compare them with a calibrated temp sensor? => both TPA's need an offset?
