TrackerSensor v4 not reading
https://www.dfrobot.com/wiki/index.php/Line_Tracking_Sensor_for_Arduino_(SKU:SEN0017)
I'm using this sensor, same code same wiring but not working.
First in the diagram shows that the VCC should be in power 5v or 3.3v and "S" is on pin2, but the red light indicator is not lighting up in the sensor and the reading is all zero white and black surface, then I swap the "S" and Vcc and the red light is lighting but the problem is it keeps on 1 value in Serial monitor tested in black and white surface.
I don't know what's wrong because I tested my atmega2560 and its working on other sensors like distance and also motors
Gee, do you think that maybe your sketch and a picture of your wiring just might help us in helping you? When taking the picture, use plenty of light and an angle that CLEARLY shows all the connections.
Do not cross post!
