Tracking with Decawave DWM1000
Hello all, i'm trying to build a tracking system using 3 anchors that will track one tag all using the Decawave DWM1000 chip. The tag collects the distance from the 3 anchors and the results will be used for trilateration. I have no problem getting this initial setup working, my issue is that the tag needs to provide output to a computer and as a result, I can't have it communicate through the serial port as this would be a wired connection. My solution is to build a receiver that will communicate with the tag and collect the distance results. I tried to implement the send and receive routines as demonstrated in the examples from this library. However I'm having trouble building a receiver that will accept the data from the tag as I keep getting a garbled output. If anyone has any experience with this, I would love some input on the Arduino code, because I have seemed to hit a roadblock. I am using Arduino pro mini and the latest version of the Arduino IDE if that helps. Cheers!
Here is the code I am working with. Apologies for the messy code, I've been modifying these frequently. The goal of these sketches was first to just pass a string that says hello from the tag to the receiver and extend that to sending over an anchor ID and range.
Here is the code for the receiver:
 * @todo
 *  - move strings to flash (less RAM consumption)
 *  - fix deprecated convertation form string to char* startAsAnchor
 *  - give example description
#include <SPI.h>
//#include <DW1000.h>
#include "DW1000Ranging.h"
// connection pins
const uint8_t PIN_RST = 9; // reset pin
const uint8_t PIN_IRQ = 2; // irq pin
const uint8_t PIN_SS = SS; // spi select pin
// DEBUG packet sent status and count
volatile boolean received = false;
volatile boolean error = false;
volatile int16_t numReceived = 0; // todo check int type
String message;
  // initialize the driver
  DW1000.begin(PIN_IRQ, PIN_RST);
  DW1000.select(PIN_SS);
  Serial.println(F("DW1000 initialized ..."));
  // general configuration
  DW1000.newConfiguration();
  DW1000.setDefaults();
  DW1000.setDeviceAddress(6);
  DW1000.setNetworkId(10);
  DW1000.enableMode(DW1000.MODE_LONGDATA_RANGE_LOWPOWER);
  DW1000.commitConfiguration();
  //Enable the filter to smooth the distance
  //DW1000Ranging.useRangeFilter(true);
  //we start the module as an anchor
  //DW1000Ranging.startAsAnchor("82:17:5B:D5:A9:9A:E2:9F", DW1000.MODE_LONGDATA_RANGE_ACCURACY,0);
  char msg[128];
  DW1000.getPrintableDeviceIdentifier(msg);
  //Serial.print("Device ID: "); Serial.println(msg);
  DW1000.getPrintableExtendedUniqueIdentifier(msg);
  //Serial.print("Unique ID: "); Serial.println(msg);
  DW1000.getPrintableNetworkIdAndShortAddress(msg);
  //Serial.print("Network ID & Device Address: "); Serial.println(msg);
  DW1000.getPrintableDeviceMode(msg);
  //Serial.print("Device mode: "); Serial.println(msg);
  // attach callback for (successfully) received messages
  DW1000.attachReceivedHandler(handleReceived);
  DW1000.attachReceiveFailedHandler(handleError);
  DW1000.attachErrorHandler(handleError);
  // start reception
  receiver();
void handleReceived() {
  // status change on reception success
  received = true;
void handleError() {
  error = true;
void receiver() {
  DW1000.newReceive();
  // so we don't need to restart the receiver manually
  DW1000.receivePermanently(true);
  DW1000.startReceive();
   // enter on confirmation of ISR status change (successfully received)
  if (received) {
    //numReceived++;
    // get data as string
    DW1000.getData(message);
    //Serial.print("Received message ... #"); Serial.println(numReceived);
    Serial.println(message);
    //Serial.print("FP power is [dBm] ... "); Serial.println(DW1000.getFirstPathPower());
    //Serial.print("RX power is [dBm] ... "); Serial.println(DW1000.getReceivePower());
    //Serial.print("Signal quality is ... "); Serial.println(DW1000.getReceiveQuality());
    received = false;
  if (error) {
    Serial.println("Error receiving a message");
    error = false;
    //DW1000.getData(message);
    //Serial.print("Error data is ... "); Serial.println(message);
Here is the code for the tag that will be doing the sending:
#include <SPI.h>
// connection pins
boolean sent = false;
volatile boolean sentAck = false;
volatile unsigned long delaySent = 0;
int16_t sentNum = 0; // todo check int type
DW1000Time sentTime;
String message;
//variables
int tagID;
float tagRange;
float tagPower;
float Range1;
float Power1;
float Range2;
float Power2;
float Range3;
float Power3;
  //init the configuration
  DW1000Ranging.initCommunication(PIN_RST, PIN_SS, PIN_IRQ); //Reset, CS, IRQ pin
  //define the sketch as anchor. It will be great to dynamically change the type of module
  DW1000Ranging.attachNewRange(newRange);
  DW1000Ranging.attachNewDevice(newDevice);
  DW1000Ranging.attachInactiveDevice(inactiveDevice);
  DW1000.setDeviceAddress(5);
  char msg[128];
  DW1000Ranging.startAsTag("7D:00:22:EA:82:60:3B:9C", DW1000.MODE_LONGDATA_RANGE_LOWPOWER);
    // start a transmission
  transmitter();
void handleSent() {
  // status change on sent success
  sentAck = true;
void transmitter() {
  // transmit some data
  //Serial.print("Transmitting packet ... #"); Serial.println(sentNum);
  DW1000.newTransmit();
  //place range data in String msg
  //float message = tagRange;
  message = "hello";
  DW1000.setData(message);
  // delay sending the message for the given amount
  DW1000Time deltaTime = DW1000Time(10, DW1000Time::MILLISECONDS);
  DW1000.setDelay(deltaTime);
  DW1000.startTransmit();
  delaySent = millis();
  DW1000Ranging.loop();
  message = "hello";
  //rangeSort();
   if (!sentAck) {
    return;
  sentAck = false;
  transmitter();
void newRange() {
  Serial.print("from: "); Serial.print(DW1000Ranging.getDistantDevice()->getShortAddress(), HEX);
  Serial.print("\t Range: "); Serial.print(DW1000Ranging.getDistantDevice()->getRange()); Serial.print(" m");
  Serial.print("\t RX power: "); Serial.print(DW1000Ranging.getDistantDevice()->getRXPower()); Serial.println(" dBm");
void newDevice(DW1000Device* device) {
  Serial.print("ranging init; 1 device added ! -> ");
  Serial.print(" short:");
  Serial.println(device->getShortAddress(), HEX);
void inactiveDevice(DW1000Device* device) {
  Serial.print("delete inactive device: ");
void rangeSort()
  tagID = (int) DW1000Ranging.getDistantDevice()->getShortAddress(),HEX;
  tagRange = (float) DW1000Ranging.getDistantDevice()->getRange();
  tagPower = (float) DW1000Ranging.getDistantDevice()->getRXPower();
  if (tagID == 1) {
    Range1 = tagRange;
    Power1 = tagPower;
    else if (tagID == 2) {
    Range2 = tagRange;
    Power2 = tagPower;
    else if (tagID == 3) {
    Range3 = tagRange;
    Power3 = tagPower;
  void print() {
  Serial.println(Range1);
  Serial.println(Power1);
  Serial.println(Range2);
  Serial.println(Power2);
  Serial.println(Range3);
  Serial.println(Power3);
It doesn't. You have problems, that you didn't share, with some code you didn't share, sending data using radios that a deep, dark secret.
I'll bet that you can figure out some things that might actually help.
PaulS:
Apologies, I updated the question with my code.
