Traffic Light - Button
I made a simple circuit with my Arduino Uno board. I added 3 LEDs and a button. When the button is pressed i want the sequence to stop. I wrote the following code and my question is: Is there any way that i can stop the sequence no matter which LED the sequence is? Do i have to check the buttonstate with If statement after each LED?
Thanks in advance :smiley:
const int redled = 9;
const int yellowled = 8;
const int greenled = 7;
const int button = 2;
int buttonstate = 0;
    pinMode(redled, OUTPUT);
    pinMode(yellowled, OUTPUT);
    pinMode(greenled, OUTPUT);
    pinMode(button, INPUT);
  buttonstate = digitalRead(button);
  while(buttonstate != HIGH){
    red_led();
    delay(4000);
    yellow_led();
    delay(2000);
    green_led();
    delay(4000);
   if(buttonstate == HIGH){
     digitalWrite(redled, LOW);
     digitalWrite(yellowled, LOW);
     digitalWrite(greenled, LOW);
void red_led(){
  digitalWrite(redled, HIGH);
void yellow_led(){
  digitalWrite(yellowled, HIGH);
void green_led(){
  digitalWrite(greenled, HIGH);
Yes. As well as reading the state after each delay().
Of course, your switch will be very unresponsive due to the delays.
Have a look at the BlinkWithoutDelay that comes with the IDE and at Demonstration code for several things at the same time
You might get the idea how to approach your problem.
