i need help fixing my code so that when i shine light on the photoresistor it turns the light off but when it breaks the light will flash then turn off
int PR = A0; //Analog 0 to Photoresistor
int light = 2; // lightpin
pinMode(light, OUTPUT);
pinMode(PR, INPUT);
digitalWrite(light, LOW);
int Read = analogRead(PR);// "Read" reads analog0 data
Serial.println(Read);// Print that data
if (Read > 900)
digitalWrite(light, LOW); // turns on
else //if the value is greater than 120
digitalWrite(light, HIGH); // turns on
A small finite state machine comes to mind. It can have three states
On
Flash
Off
You can go from 'Off' to 'On' if there is no light on the sensor, from 'On' to 'Flash' if there is light on the sensor and from 'Flash' to 'Off' after a time has lapsed.
Finite state machines are often implemented using a switch/case.
Your topic is not related to problems with the IDE and hence has been moved to a more suitable location on the forum.
For a start add the flash to the off cycle such that it must flash before turning off. This will get you started but there will be more things as you progress with the assignment.
Both conditions (light shine, light break) result in "off"... do you want "light shine = off" and "light break = flash"? Right now, you turn the light ON, OFF Maybe you want to turn the light ON, OFF, ON, OFF for flashing?
pinMode(PR, INPUT);
if (Read > 900)
digitalWrite(light, LOW); // turns on <<-- CATHODE TO PIN, ANODE TO VCC
// digitalWrite(light, LOW); // <-- LIGHT WAS "LOW"
else //if the value is greater than 120 << THIS COMMENT SHOULD READ "IF GREATER OR EQUAL TO 900"
delay(250);
delay(250);
