#include "ArduinoGraphics.h"
#include "Arduino_LED_Matrix.h"
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int ledPin = 13;
const int piezoSensor = A0;
const int threshold = 100; // Threshold for motion detection
const int buzzer = 12;
const int switchPin = 11;
const int switchPin2 = 10;
int sensorReading = 0;
int switchState = 0;
int previousSwitchState = LOW;
int switchState2 = 0;
unsigned long switchStartTime = 0;
bool switchWasHigh = false;
bool alarmActive = false;
bool matrixDisplayed = false; // To ensure matrix message only appears once
lcd.init();
lcd.backlight();
pinMode(switchPin, INPUT_PULLUP);
pinMode(switchPin2, INPUT);
pinMode(ledPin, OUTPUT);
pinMode(buzzer, OUTPUT);
Serial.begin(115200); // Start Serial for debugging
// Default LCD message
lcd.setCursor(0, 0);
lcd.print("System Ready");
switchState2 = digitalRead(switchPin2);
switchState = digitalRead(switchPin);
// ---- Door Closed ----
if (switchState2 == LOW && switchState == LOW) {
lcd.clear();
lcd.print("Door Closed ");
return;
// ---- Door Open & Alarm Countdown ----
if (switchState2 == HIGH && switchState == HIGH) {
if (!switchWasHigh) {
switchStartTime = millis();
switchWasHigh = true;
lcd.clear();
lcd.print("Door Open");
for (int i = 10; i >= 0; i--) {
if (digitalRead(switchPin) == LOW || digitalRead(switchPin2) == LOW) {
lcd.clear();
lcd.print("Door Closed");
return;
lcd.setCursor(0, 1);
lcd.print("Alarm in ");
lcd.print(i);
lcd.print(" ");
// ---- Trigger Buzzer After Countdown ----
if (millis() - switchStartTime >= 10000 && switchState2 == HIGH) {
digitalWrite(buzzer, HIGH);
// ---- Cancel Alarm if Switch is Flipped ----
if (switchState2 == LOW || switchState == LOW) {
digitalWrite(buzzer, LOW);
lcd.clear();
if (switchState2 == HIGH && switchState == LOW) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Alarm Cancelled ");
lcd.setCursor(0,1);
lcd.print(" ");
// ---- Motion Detection ----
sensorReading = analogRead(piezoSensor);
// Print sensor reading to serial monitor for debugging
Serial.print("Piezo Sensor Reading: ");
Serial.println(sensorReading); // Output sensor reading to serial monitor
// If the switch is ON (i.e., alarm system is activated)
if (switchState == HIGH) {
if (previousSwitchState == LOW) {
alarmActive = true;
previousSwitchState = HIGH;
// If piezo sensor reading exceeds the threshold
if (sensorReading >= threshold) {
digitalWrite(ledPin, HIGH); // Turn on LED
digitalWrite(buzzer, HIGH); // Turn on Buzzer
lcd.print("Motion Detected ");
delay(5000); // Keep the LED and buzzer on for 5 seconds
digitalWrite(ledPin, LOW); // Turn off LED
digitalWrite(buzzer, LOW); // Turn off Buzzer
lcd.print(" "); // Clear motion detected message
} else if (previousSwitchState == HIGH) {
if (switchState2 == HIGH) {
lcd.clear();
lcd.print("Door Open ");
And the 1.000.000 $ question is ... ?
Welcome!
Purple!
What is the question. Where is the annotated schematic? Where is the description of what it is? Without enough information you will get a simple answer "purple".
Purple is the wrong answer!
The correct is answer is 42 ![]()
Is that before or after the hitch?
Let's ask the mice.
To eat or not to eat, that is the question ...
