Hello,
I am building an aerial tramway model. The cabin is suspended on a long cable reeled around a drum powered by a DC motor. The motor speed and direction is controlled by an H-bridge. I am using the ultrasonic sensor HC-SR04 to determine the distance between the tramway and the station. How I want it to work is: If fDistance is less than 5cm, then the motor will roll in one direction; and if fDistance is more than 100cm, then the motor will roll in the opposite direction, thus make the cabin come back.
The problem that I encountered: When (5<=fDistance<=100), the motor does not keep its current direction. Please help me out with the coding for the main loop.
const int In1 = 3;
const int In2 = 5;
const int In3 = 6;
const int In4 = 11;
#define echoPin 7 // Echo Pin
#define trigPin 8 // Trigger Pin
//#define LEDPin 13 // Onboard LED
int speedL, speedR, time, fDistance, Low, High;
long duration, distance; // Duration used to calculate distance
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(In1, OUTPUT);
pinMode(In2, OUTPUT);
pinMode(In3, OUTPUT);
pinMode(In4, OUTPUT);
void forward(int speedR)
analogWrite(In4, 0);
analogWrite(In3, speedR);
void reverse (int speedR)
analogWrite(In4, speedR);
analogWrite(In3, 0);
void stop() //Makes wheels stop
analogWrite(In2, 0);
analogWrite(In1, 0);
void scan()
/* The following trigPin/echoPin cycle is used to determine the
distance of the nearest object by bouncing soundwaves off of it. */
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
Serial.println(distance);
//digitalWrite(LEDPin, LOW);
if(distance == 0) //If no ping was recieved
distance = 100; //Set the distance to max
//Delay 10ms before next reading.
delay(10);
