the problem is that I want to transfer a number of pieces by analogWrite to a another arduino which it display the number 00 to 99... I have utilise all of my 14 digital pins on that arduino... but the arduino doesn't red number ... I tried a Serial.print... I'am a beginner... I made a nother program to check if I can display my number and it works
A part of my program of the count
boolean A,B,C,D,E,F,G,a2,B2,C2,D2,E2,F2,G2;
float chiffre;
int dix_exp_un;
int dix_exp_zero;
void setup(){
pinMode(0,OUTPUT);
pinMode(1,OUTPUT);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
pinMode(13,OUTPUT);
pinMode(A2, INPUT); // lautre arduino indique le nbre de piece qui reste a usiner
void loop(){
chiffre = analogRead(A2/10);
dix_exp_un = int(chiffre/10); // if we had 79 pieces then base_dix = 7
dix_exp_zero = chiffre-(dix_exp_un)*10;
boolean start, Start, OK, MG, MD,jog_up,aucune_piece_restant_a_usiner, jog_down, haut, bas, monte, descend, piece_plus,piece_moins, man_auto;
boolean reset = 0;
boolean down =0;
boolean up=0;
int nombre_de_piece_a_usiner;
int piece_usiner;
int p =0;
int piece_restant_a_usiner;
void setup(){
pinMode(0, INPUT); // MAN /AUTO
pinMode(1, INPUT); // JOG monte
pinMode(2, INPUT); // JOG descend
pinMode(3, INPUT); // start ok pour le nbre de piece
pinMode(4, INPUT); // bouton gauche
pinMode(5, INPUT); // bouton droit
pinMode(6, INPUT); // haut
pinMode(7, INPUT); // BAS
pinMode(8, INPUT); // OK
pinMode(9, INPUT); // nbre de piece a usiner ++
pinMode(10, INPUT); // nbre de piece a usiner --
pinMode(11, OUTPUT); // PL pu de piece a faire
pinMode(12, OUTPUT); // Monte
pinMode(13, OUTPUT); // Descend
pinMode(A0, OUTPUT); // indique le nbre de piece a faire a lautre arduino
void loop(){
man_auto = digitalRead(0);
jog_up = digitalRead(1);
jog_down = digitalRead(2);
start = digitalRead(3);
MG = digitalRead(4);
MD = digitalRead(5);
haut = digitalRead(6);
bas = digitalRead(7);
OK = digitalRead(8);
piece_plus = digitalRead(9);
piece_moins = digitalRead(10);
if(MG == 0 && MD == 0 && haut ==0){
monte = 1;
if(haut == 1 && MG==0 && MD == 0){
monte = 0;
descend =0;
if(piece_plus == 1 && piece_moins == 0){
p = p +1 ;
if(piece_plus == 0 && piece_moins == 1 && p >= 1 ){
p = p -1;
if( OK == 1){
nombre_de_piece_a_usiner = p;
} // on sait maintenant comment de piece on veut usiner
if(man_auto == 1){
monte=!descend;
if(jog_up == 1 && jog_down == 0){
monte = 1;
if(jog_up == 0 && jog_down == 1){
descend = 1;
if(jog_up == 1 && jog_down == 1){
reset = 1;
}// mode manuel
if(start == 1){
Start = 1;
if(Start == 1 && MG==1 && MD == 1 && man_auto == 0 ){
if(piece_restant_a_usiner > 0){
if(haut == 1) {
down = 1; // memoire que ca descend
monte =0;
if(down == 1 && bas == 0){
descend = 1;
up = 0;
if(bas == 1){
descend = 0;
piece_usiner = piece_usiner + 1;
up = 1; // memoire que ca monte
if(up ==1 && haut == 0){
monte = 1;
down = 0;
}//nombre_de_piece_a_usiner > piece_usiner
if(piece_restant_a_usiner == 0){
aucune_piece_restant_a_usiner = 1;
reset = 1;
}// MG et MD == 1
if(reset == 1){
Start = 0;
piece_restant_a_usiner = 0;
nombre_de_piece_a_usiner = 0;
piece_usiner = 0;
up = 0;
down =0;
reset =0;
piece_restant_a_usiner = nombre_de_piece_a_usiner - piece_usiner;
digitalWrite(11, aucune_piece_restant_a_usiner); // PL pu de piece a faire
digitalWrite(12, monte); // Monte
digitalWrite(13, descend); // Descend
analogWrite(A0, piece_restant_a_usiner*10);
lab_12_chiffre.ino (3.57 KB)
lab_12_prog.ino (2.78 KB)
