Transfer files using the Arduino Wireless SD Shield and XBee
Hello all!
So, here's the situation. I have an Arduino AtMega with a bunch of sensors connected to it, and I'm printing all this data in neat .csv files on the microSD. So far, so good.
What I want to know is what's the simplest, most foolproof way to get this data onto a PC without having to take out the microSD.
A few ways I've been looking at: Use FTP. http://playground.arduino.cc/Code/FTP The problem is that from what I've read, this is meant for Ethernet. The Ethernet board has 4 sockets, wireless shields seemingly have only one, so I didn't find anyone who got this to work wireless (http://forum.arduino.cc/index.php?topic=150810.15). It would pretty easy and great if I could get this to work though.
Use a PHP script to receive data on a server (something like http://forums.parallax.com/discussion/159854/xbee-wifi-send-and-receive-data-from-web). I don't know PHP, but I'm willing to learn, so that would be quite a learning experience. If it can be done I'll try it, but I'd rather do something less intimidating.
Send the data byte-by-byte. Not sure what would be the best way to receive it, but since it's just .csv files, this would be pretty simple to do.
Also, the reason I haven't started experimenting yet is because the XBee antenna is in the mail, should come in in a few days.
To be clear, I'd want the XBee to connect to a local WPA2 network, send data to this network, and somehow receive this data on a PC connected to the same wifi network.
How intimidated you are is not something we can judge. PHP uses a lot of C syntax, so the code will look a lot like the Arduino code.
All data is, ultimately, sent byte-by-byte. The best way to receive it is byte-by-byte.
An XBee can't do that. An XBee-Wifi can, but they are not XBees as most of us understand the term.
PaulS: How intimidated you are is not something we can judge. PHP uses a lot of C syntax, so the code will look a lot like the Arduino code. All data is, ultimately, sent byte-by-byte. The best way to receive it is byte-by-byte. An XBee can't do that. An XBee-Wifi can, but they are not XBees as most of us understand the term.
That's good to hear, about PHP. Transferring byte-by-byte would be my preferred method, yes. I'm just not sure where to look to get started to upload those bytes somewhere. Also, sorry for the imprecision, it is a XBee Wifi, this one to be precise: https://www.sparkfun.com/products/12568 .
I've also found about the Phant library, which seems to be useful for turning the raw data into a format that can be uploaded to the web. https://github.com/sparkfun/phant-arduino
It just sounds like the XBee would have to host a webserver to do all that, and I have no idea where to start with that. Is that even possible, or am I misunderstanding and it's just communicating with a webserver hosted elsewhere?
Please be careful to use XBee-Wifi when you are referring to something that is not what we typically refer to as an XBee.
Your wifi device will need to be a server if you want to upload data to it. It will need to be a client if you want it to upload data to some other server (which is what I understood you to want to do).
