Transfer from Arduino to breadboard
This is probably a totally noob question but i need to know.
After developing on the Arduiono Diecimila which has been a lot of fun (software guy, trys hardware), can I take the ATmega168 out of the Arduino board and use it on a breadboard or pcb ?
I’m thinking yes, once the code has been uploaded it’s going to be usable.
But how do the Arduino i/o pins relate to the chip and can I just connect up the way I did when using the board or are there critical stuff on the arduino board which needs to be replicated.
Basically, I want to know how to convert a prototype to an actual stand-alone device without sacrificing my lovely Arduino.
Thanks
It’s definitely possible, and one of the main reasons for using DIP packages on the Arduino board.
Check out the hacking section of the site: http://www.arduino.cc/en/Hacking/HomePage. In particular, there’s a diagram of the mapping of the Arduino pins to the ATmega168 pins: http://www.arduino.cc/en/Hacking/Atmega168Hardware.
If you want your code to run unchanged, the main thing you need is a 16 MHz oscillator and the two capacitors that work with it. See the Diecimila schematic for details: http://www.arduino.cc/en/uploads/Main/Arduino-Diecimila-schematic.pdf. You also need a way to power the chip, of course, and probably a way to reset it (besides just pulling the power). If you’re going to want to program it on a breadboard, you’ll probably want to hook up the auto-reset, which involves putting a 100 nano-farad capacitor between DTR (of whatever USB-to-serial convertor you’re using), and the reset line of the ATmega168. Or you can just put the chip back in the Diecimila to reprogram it.
Yes.
crystal+caps, reset line pullup resistor, regulated +5V supply, .1uF cap at or near Vcc, and probably a pullup resistor for the RX data line. (I don’t think I’ve forgotten anything.)
There’s nothing magic on the Arduino board; the biggest thing is to make sure the clock source (crystal) in the target circuit matches the settings in the ATmega’s fuse bits. If you include a crystal of the same speed as on the Arduino board, you’ve taken care of that.
Look around the Arduino site a bit, especially tutorials and the playground. You’ll find examples of homegrown arduino boards, an “Arduino breadboard”, etc.
-j
Thank you both, your answers have given me the confidence to try.
