transfer integers NRF24
I have been trying to understand how to transmit several integers via NRF24 using Robib2's
"Simple nRF24L01+ 2.4GHz transceiver demo".
Have this very basic array which I would like to transmit from TX and read it as integers on the RX module.
int Data[4];
  int i;
  Data[0] = 6;
  Data[1] = 56;
  Data[2] = 166;
  Data[3] = 2266;
  for (i = 0; i < 4; i++)
    Serial.println(Data[i]);
    delay (2000);
Serial.println ("                      ......");
Can anyone please show me how I can incorporate this array into the above NRF Demo please.
By "show me " I am hoping someone has the patience to show me the specific line of code I should write and what each command achieves.
Thanks
Assuming that you have got Robin's examples working then :
To send the array
void send()
  bool rslt;
  rslt = radio.write( &arrayName, sizeof(arrayName) );
  if (rslt)
    Serial.println("  Acknowledge received");
    Serial.println("  Tx failed");
To receive the array
void getData()
  if ( radio.available() )
    radio.read( &arrayName, sizeof(arrayName) );
    newData = true;
I hope that it goes without saying that the array has to be declared on the Rx side
Thanks for the reply I will see how I go with it in the Morning.
Could you explain the term "bool rslt;" doe's?
Is the "rslt" just like naming a variable and could it just have been any word at all?
As I cannot find any expression called "rslt" I assume that it is not a function.
Also the "if rslt".
It seems to me that "if" checks that there is a value to "rslt" and if there is it prints an acknowledgement.
Thanks for your time
Farticus:
Yes it is a variable. You could call it "elephant"
Also the "if rslt".
That's exactly the same as
if (rslt == true) {
...R
